Safe to say I am VERY happy with this exhaust. Quiet on idle but tear-you-a-new-asshole aggressive when you open it up. This was running gate pressure of 7psi and only revving to 5k as I'm slowly working up the boost and RPM. It's so hard to not drive it like this all the time!
I love the cracks from the exhaust when you get off the loud pedal, it does it in every gear and sounds absolutely nuts hahaha!
  • Like 2
  • 2 months later...
This things isn't dead. I swear.
Flavour of the month at the moment is a weld leaking from where the fitting for the VCT was welded to the head. Nothing is able to stop it. Long story short engine is back out and head has gone away to be fixed. Will be drilled and tapped rather than getting a fitting welded on.
So just getting a general tidy up while there is no engine in the bay. Relocating power distribution block, installing castor arms (the only non standard arm in the car even after 2 years drifting haha), removing front swaybar because front wheels hit it now due to extra steering lock.
Picked up a new pair of rims to help combat the issue. 18x8+38 AVS model 5's. Love these wheels just shit sizes, will run them with a 25mm spacer on the front which should give me plenty of inner clearance.
Decided to paint some Shit too because it looks pretty average without paint. Used VHT wrinkle coat and it came out pretty good, I'm impressed.
Goes for tune (hopefully) at DVS JEZ on 16th feb and (hopefully) making its debut at Streetkarnage Halfway Hangs at RALEIGH raceway 20th feb lol. Last minute hustle come at me.
post-84937-14227870826244_thumb.jpgpost-84937-14227873283283_thumb.jpgpost-84937-14227873451897_thumb.jpgpost-84937-14227873651203_thumb.jpgpost-84937-14227873805948_thumb.jpgpost-84937-14227873966576_thumb.jpgpost-84937-14227874124231_thumb.jpgpost-84937-1422787426036_thumb.jpgpost-84937-14227874457249_thumb.jpg
Absolutely.
Just a shame I didn't think of it back in September last year when it first started leaking. Fabricator was positive he could re-weld it and it would be fine. After 3 attempts over 3 months I finally cracked the shits and said tap it.
Lend me some motivation. Guy who originally welded my head for VCT oil line f**ked it and actually cracked the head somehow and it's now leaking. Tried to fill it with JB weld and it got into the crack and now cannot be welded back up as no weld will take to the JB weld. Me having no idea about how any of this stuff works only found out right at the end when I got told the head is now not salvageable.
Right.
I said f**k it (lucky I had a spare neo head laying around) I will use my other head. So I took it to someone else who specialises in this work. Told them to weld VCT hole In bottom of head and deck flat, and drill and tap front of head for VCT fitting. They drilled and tapped in the wrong spot and now the fitting in the head only clears the intake manifold by 3mm. And that's with nothing screwed into it.
I'm well over getting assf**ked by supposedly reputable people. f**k newcastle, get me back to SA.
And f**k this f**king car.
Right.
Sound like you are having some back luck my friend. I hope everything works out for you. Subscribing for awesomeness!
I last read your build thread a few years ago when you were still in Wagga... I must say things have gone a 'little' crazy since then, with the RB30 etc!
I've often thought about putting an RB30 in mine, but always decide against it due to bonnet/stay bar fitment... How did it go in yours? Did you have to cut out the bonnet supports?
would the workshop that cocked up the head be liable for the damages he/she caused? If they know their RBs so well and they cocked it up so badly, surely they would just repair/replace the head so they don't get a bad rep right?
Go call Adam at JEM. Its a bit of a hike but Matt Gtt from the forums is a Newcastle boy im pretty sure and travels due to the quallity of work. Just google them or watch this video to get an idea :P If you email him he can also give you great advise and may know someone closer to yourself that can build the head you are looking for :)
post-84937-14233161831253_thumb.jpgpost-84937-14233161947272_thumb.jpgpost-84937-14233162086094_thumb.jpgpost-84937-14233162191554_thumb.jpgpost-84937-14233162475738_thumb.jpg
Engine is back in the bay and (pending no leaks from the fittings) it seems I may have sorted the VCT problem. More pics and write up tomorrow.
Also I wonder if anyone else can notice anything unusual with the VCT ;)
Spent all week tidying shit up and getting everything to a stage where I am happy with it.
Now it's all loaded on the trailer off to get tuned tomorrow. Hopefully 12 months of hard work and disappointment after disappointment with people letting me down come to an end and I get a decent result tomorrow!
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
