On 21/10/2016 at 10:35 AM, White_Stag said:
Hi guys does anyone have parts numbers for Rocker cover gaskets and seal for back of oil cooler. I'm having slight oil leaks.
Thank you!
The part numbers for both rocker cover gaskets is in the first post of this thread.
Did you even try looking before posting?
  • 2 months later...
Hi there, nice thread!  I have been having a look through.. and in another thread here, regards bodywork. I got the impression many of the body parts are interchangeable. My 2003 nm35 ARX suffered a ram from a commodore the other day. I am looking for a replacement rear bump/bar and reinforcing rail and want to check that a series 2 will fit on my series 1 or if any M35 rear bumpers WONT fit on the AR-X?
Cheers!
Cheers!
There is a ARX kit for sale on facebook and i have a spare rear reinforcement bar (currently wrecking a m35)
Thanks for the 2 responses above! I'm in New Zealand, we don't get very many of the ARX VQ25DET here! I have been ill so fixing this is still a work in progress.
While on the subject of the backend of a VQ25DET, I  thought to raise the question on tow bars. I am guessing this is possible for the vehicle with a standard factory turbo setting?  I must admit I  get a bit out of my depth there, was wondering if the fixings may require a special reinforcing bar on the off chance. At which I may look into setting this up while doing the repair.
thanks again for the replies and this awesome thread.
Username is surname with an S at the end, also an anagram of Stagea. Love my badge haha.
Edited by Agates
  • 5 weeks later...
If it's a help to anyone, the official Nissan M35 Aircon condenser assembly (with receiver/dryer tank) part no. is 92100-AL570 (replaces original part no 92100-AL500).
The same condenser/tank assembly fits the following models:
STAGEA GH-M35, GH-NM35, GH-HM35,
STAGEA CBA-PM35, CBA-PNM35,
SKYLINE GH-V35, GH-HV35, GH-NV35,
SKYLINE CBA-CPV35, CBA-PV35
SKYLINE UA-CPV35, UA-PV35
So there.
  • Thanks 1
  • 1 month later...
P0110 CEL
nm35s are known for killing airflow meters.
It appears the problem is not the airflow meter itself just simply the attached thermistor.
I have tracked down the correct part a repaired 2 of my previously failed 5.
I wish I had of known this originally. The thermister is simply clipped into place and develops a resistance based on temperature. This tells the ecu what the intake air temperature is.
If you are having this error code come up the part required is;
http://www.newark.com/honeywell/135-202fag-j01/ntc-thermistor/dp/10M5322?CMP=AFF-CJ-3196515-Newark+Product+Catalog&source=CJ
  • Like 1
anyone know if the m35 shares CV's with any other car? 2-3 years ago I had torn boot and fixed it. now its happened again and they got plenty of play in them.
would make it easier if they were shared with another make..
On Monday, April 03, 2017 at 0:27 AM, m35stagea said:
P0110 CEL
Wow! If this is true, you really should post a topic on this. So many people have had issues with this. I am on my 4th maf sensor. I will try it out on one of the faulty ones. Thank you! L
  • 2 months later...
Does anyone have the part number(s) for a seal kit for the front brake calipers?
I rang nissan up and they quoted a part number: AY600NS013.  This is 2-3 weeks from Japan!  Surely this should be the same seal kit as the 350Z?
Another website was quoting 41120-AL525, but I have been told this is for a Nissan Juke.
if your blowing up AFM's I'd be looking at your air filters. Especially if they are an oil type Like K&N or BMC etc etc.
(no reason why they wont last 120,000km / 15 years)
  • 1 month later...
The info in the first post re: front wheel bearing on NM35 being the same as J32 Maxima is incorrect.
I ordered an aftermarket J32 Maxima bearing and hub assy from Bursons and attempted to fit it, but found the bearing carrier to be too large to fit the stub axle.
The CORRECT part number for an aftermarket bearing is NJ137KIT - this is a CBC part number, and should be available from most bearing places.
  • Like 1
  • Thanks 1
Thanks - i've updated the front page with your info.
  • 1 month later...
RHR Lower Door Seal:
82838-AQ01A
List Price: $99.06+
LHF Lower Door Seal:
80839-AC50B
List Price: $95.15+
Required Clips:
80897-AQ000
x11 to do one front, one rear door
  • 5 weeks later...
Couldn't be bothered searching to see if this is known;
VQ35 starter motor is a direct replacement for VQ25DET.
I have just fitted one after mine cooked itself. Bolts straight in with no modifications at all and no clearance issues. They share the same solenoid as well.
Edited by Sack87
Spelling mistake
  • Like 3
  • 6 months later...
Quote
Rear rotors and pads are the same as the 350z touring/V35 Skyline/X-trail
The rear pads & rotors for the 350z or v35 will not fit without modification
Can someone clarify what this means form the first post. I've read the whole thread a few time but can't find deets on the
modifications (if any) are required to rear pads and or rotors/
  • 2 years later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
