Hahaaa, you guys.
1) I'm not wrapped in wrap - no. But I'll sit on it for a couple of months before I rid myself of it. Other priorities I guess. Sure, it's done 84,000Km but asap, the 100,000Km service needs to be done. And I don't know if the tune is currently only on Japanese fuel RON
2) Yes, N1s are great in concept. I've always admired the M3 in CSL guise. And could never understand why their owners packed the weight back on with luxuries.
3) Getting a hoist Hayden to accommodate another car in a 2-car-garage.
I owe a lot to this here Club - SAU.
And accolades go to Iron Chef who brought in the BNR34 N1 in 2011 and the BCNR33 N1 3 months ago (inspecting them on the ground, before they went to auction).
  • Like 3
  • 4 weeks later...
Can I join in even if I don't have them any longer? (Still breaks my heart to say that).
The original SAU GTR...
3palm_beach_shoot_001.jpg.pagespeed.ce.-
And, the baby... This one still melts my heart. (I still have the C10 GTR badge)
gallery_3_9_97688.jpg.pagespeed.ce._WT80
  • Like 3
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
