26 minutes ago, bcozican said:
Id like to race in the US i think alot of those track would suit me
For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too.
Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
  • Like 1
  • 4 months later...
Posted (edited)
it takes so long to get things done but ... they are nearly there and we hitting the track soon again
So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits
The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one
At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order
While all this was happening the new MCA golds turned up and did some fiddling around with those
Put in the flappy paddle system and clutch lockout wiring/ system
We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth
Looking for better control and faster acceleration
I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time
making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier
All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon
So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical
We'll see how all this goes
Edited by bcozican
  • Like 9
FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
  • Like 1
have no doubt and wanted too trust me and may regret later
not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better
the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha
15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
3 hours ago, robbo_rb180 said:
Solid update, got all the downforces now.
You going to be running aus time attack again?
love the jacking solution, spend the dollars on what makes it go fast is best way.
yes I intend to do the Aus Time Attack to WTAC combo again this year
im exhausted already just from the thought 😆
  • Like 2
  • 2 months later...
This thing did a 1:20.88 at Winton on the weekend which is f**king rapid
Well done mate, your driving has really gone up a few notches not much left on the table now! Good luck at WTAC.
https://www.facebook.com/share/r/1MHyZQBqZ2/
Edited by Komdotkom
  • Like 4
Thanks mate
It's all coming together finally. It's just a better racecar now and also yeop I've pulled my thumb out and committed and the combo seems to be gelling
Depends what you mean by not much more haha
There's at least a 1.19 in this
My fastest lap posted lost 3.5 tenths in T10 and this was on 80% power and 5 heat cycle old tyres
The next session/ lap we did we were up 4 tenths with the car out of the final turn T12 accelerate straight and going with 1 or 2 tenths to come from the power to the finish line and the shifter/gbox combo stopped selecting
So we wouldve had it. The whole thing..
Also repeated this the very next lap up 3 tenths out of T10 and same issue
Add some news tyres and we good
Looking forward to a break then yeop WTAC and see if we can actually have a decent run
  • Like 7
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
