engine just "blew".
you speak like the kind of person that buys crate motors and then tells the world to not buy from that engine brand ever again, and that you'll just get an R32 golf and make weird DSG noises all day.
and that $0 engine got you incorrect ARP studs and who knows what other goodies.
I feel for you and the car, seriously... but its almost like you hammer the shit out of the car until something lets go. skylines are perfect for that, but with so many mods cars get temperamental. Did you feel or hear anything weird? does the engine run at all? did engine oil get really hot just before it died?
How will/did you manage to accomplish this?
Say you worked at 20 to 30. 10 years.
You would have to be on an average salary of $220k p.a
So about $70k in tax, and say $50k in spending a year.
Would leave $100k in savings over 10 years
it's quite doable also haven't factored in profits on investments & also combined income as opposed to individual
But alas haven't gotten there .... Yet.
Finishing strong tho #boommarket #yay
not that it matters but did start working at 18.. Well technically 14 and 9 months but eh maccas casual didn't equate to much lol
Edited by alr33x
engine just "blew".
Mate, I am the most timid driver on all of SAU. This was no level of rage driving or drifting or 400RWKW in school zones or anything.
I got it on Friday afternoon/night. I drove it maybe... 50kms around town, under the speed limit, off boost just to check for leaks. I had the haltech logging EVERYTHING the entire time, TPS, road speed, boost, gears, etc, everything. I do mean everything, super super casual driving just happy to drive the thing.
I drove it a bit on Tuesday because hey, its back! And Hey, I may as well give it a drive (i.e in the same casual manner) to Mt Donna Buang. Traffic was huge, but I didn't care, so I just putted along behind a camry the entire time.
I did think okay, it seems to drive around reasonably well, lets try some boost and immediately blew an intercooler pipe off at 10ish psi. Pulled over, fixed. Did again, blew off a different one, pulled over, fixed. Did this 2 or 3 more times then said "Oh well, its getting late, I'll head home now and didn't really hammer it but there will be many more days"
Except there wasn't, because I passed a dude doing 90kmh on Maroondah highway in a passzing zone by going 30% throttle in 4th gear to pass him.
Then I noticed I was running on 4 cylinders instead of 6, and the coolant gauge which I have mounted in the DIN slots so I can monitor things went from 62C (running temp) to 65 (hmm) to 68 (uhhh) and was 80 before I pulled over and immediately shut the engine off. The engine oil temp was normal at the time the HG went (180F)
Then I checked the oil cap and there you go.
I am not the kind of person who redlines an engine until it explodes. It blew, at most, under load which would be something like 50rwkw.
Fair enough!
When you said cash i just thought you had just been saving $$$
Have you been investing in shares on the property market?
I'd assume property as you do that for a living
Finishing strong as in there is a bubble which has popped?
  • Like 1
so milky oil as in head gasket? in the pic I just thought that was normal for E85 use... thats how everyone described the oil turning creamy.
when you say blow motor i immediately thought bottom end.
and when you were curious about different boost levels in different gears, i imagined you testing it by tearing up every road around lol. and before that the car slide out in the hills and hit something.
No, it is never like that for E85... it also wasn't like that when I checked the intercooler piping about 20 minutes before the gasket let go. (because oil in charge pipes).
The Head Gasket is what has let go (or something else that mixes coolant and oil...) at most 150kms since a new gasket (Tomei!) and new ARP2000 head studs have been put in.
Surprises all round, really.
In the thread re: Different boost in different gears I also mentioned that this happens at vacuum levels too, it happens across the entire spectrum and is an Auto gearbox thing, the crash in the hills was at 30kmh off throttle entirely in the rain, across standing water and mud.
Can we include super and inheritance in our millionaire pooling? What about virtual investment?
Gabi Grecko managed to do it with her household income at age 26
Potential Inheritance! Yes! I'm already there!
Nearly happened to trent back in the day too. Drive shaft snapped when one of cats old race car was on the dyno at creatd and trent was in the back seat.
That was the reason for all the dodgy Chequereplate in the middle of creatd's dyno lol
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
