do track day b4 fitting
+1
blah_blah got full GTR kit + full spray.. too clean to track now. if you wanted mechanical + exterior mods, should have bought someone else's package IMO. especially if you're on a budget.
Not turning it into a full track car, just keen to do a few days :)
+1
Have to agree with the below comment haha. I would prefer to do up my current car even if it costs me a bit more. I have a budget for the mods I'm doing, but that doesn't mean I don't have the money if that needs to extend ;) Saving up for other things instead, car gets a certain percentage.
+1
Weak as f**k excuse serious. Vu charges like $200 to spray a front bar.
*googles mechanic wages* never knew what they actually earnt
actually on that subject mrs works at super a mart casually, overheard & told me the full time sales dudes get $18 p/h, not sure what / if there's commission
surprised me a little bit.
edit: why wouldn't they just sell houses instead and get dat dere 6figs?
#rustlingsomejimmies
Edited by UNR33L
The more people present the less accountability per team member. Which can result in a bigger pisstake for something which needs to be taken seriously lol
Sounds like we need to FIFO Pat in to oversee the change management processes
Sorry brah we ain't all on oil changer wages
Get on my level brah
The worst part About Borcis job is when I bring my r32 in.
I try to tee up 2 weeks of holidays whenever you're booked in because thats how much time needs to be spent on yours to make it okay.
Because he has to interact with you?
Nailed it.
I prefer when they actually give them to you rather than show in the magazine....
what I have to put up with for breakfast sat.
http://www.ausbt.com.au/files/Qantas%20First%20Lounge%20-%20Spring%202015%20-%20Breakfast.pdf
I'm gonna state in advance, and no offence intended Greg, but you are banned from attendance
Was gonna say there's a NEO engine for sale for $2500.
I can't even f**king pay people to do this kind of thing for my car, 100% confident a stock engine will last a lot longer than getting whatever the f**k has gone wrong with mine this time fixed.
I am very used to something like a direct engine swap, when I can get the engine there, just taking 12 weeks because reasons. If y'all can actually get it done in a couple hours I'll just go punch myself in the face some more.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
