  • 1 month later...
On 11/9/2020 at 11:15 AM, SimonR32 said:
Updates on the Albins?
No.  Over 12 weeks now and no eta to date.  Was supposed to have it by now.   Joke. I just this afternoon enquired about cancelling.
Muppets.
Edited by IMACUL8
Muppets.
Albins have moved into the defence industry sector and since this move there customer service regarding their sequentials has gone to poo.
Yes I have heard that from a few people now. Real shame.
  • Sad 1
7 minutes ago, PranK said:
Love that wheel!
Thanks Christian....  I'm having an R34 GTR wheel done at the moment as well - a man needs options!
Edited by IMACUL8
  • Like 1
1 minute ago, IMACUL8 said:
Thanks Christian....  I'm having an R34 GTR wheel done at the moment as well - a man need options!
I understand this. Wheels need to be perfect!
  • Haha 1
56 minutes ago, BakemonoRicer said:
Imagine the lead time in the event you need replacement parts
best of going with a samsonas mate! They are used in all the TRP shop cars and their after sales service is pretty spot on
Im looking into it now mate.. waiting to hear back from my workshop.
+1 for Samsonas. Can't fault the box nor the customer service.
Only downside is if parts aren't in stock they need to come from Lithuania but even that is faster than Albins at the moment...
Case on its way for Anodizing and things are moving.
At end of the day - do I really need a Albins, Samsonas, Hollinger etc?  No.
Car has never seen a track day, drags, etc.  Occasional street driving, cruzin, etc - and back in the garage.
Its way over kill for what I will ever need - but - hoping I will never have box issues again (at least not for a very long time).
I am setting up the internal oiling system on the Albins to run to a rear diff cooler (Z Tune style)....  again huge overkill for me - but fark it ;) will be functional and look amazing.  I have also slightly tweaked the shifter /strain gauge setup/look to what's offered standard.
Adding a new Motec ecu and c1212 dash etc. when the box goes in.  (thanks to Moray).
Ill just chill and wait - I'm sure this box will be more than I ever expected or needed!
Its a investment (that's what I tell myself so I don't cry) ;)
Dan
Edited by IMACUL8
speeling ;)
  • Like 1
Adding a new Motec ecu and c1212 dash etc. when the box goes in.  (thanks to Moray lol).
Ill just chill and wait - I'm sure this box will be more than I ever expected or needed! lol
Dan
Is the case the issue, because that's not made by Albins, I figured Albins is the hold up?
Albins makes the case - they send to Platinum - they anodize and send back for gear set to be installed.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
