So rolls didnt happen. Got my car all done, aircon regassed, alignment, wheels balanced. Took it home to check everything the next morning, opened the radiator and there was some oil in the rad cap. Dropped the oil and there wasnt any water so all was good. Dropped the rad and it was a bit of a milkshake party. End up pulling the motor out that night. Still not sure where the oil was pushing into the water. Will get the head all checked out and decided to sell my cams and go to a set of kelford 270/274in 280ex 10.5mm lift. The block had a couple of cracks on the deck but nothing that I could see would mix the oil into the water.
Motors now stripped down, just need to pick up another block and take it to my builder and get it all checked/machined/assembled. New cams should be here sometime this week so I'll be able to send the head away to get checked and setup for the new cams.
I have also sold my powerglide in order to fund a zf 8hp swap with goals to make the car more streetable and comfy to drive while still being able to maintain some drag racing functionality. We'll get the car back up and running and leave it on wastegate and focus on getting the box setup perfectly then we will add some power to it and see how it goes. Goal is to just drive it a lot more and be able to take my family out in it and cruise on the highway in 8th gear at 2000rpm while remaining fairly quiet. I have ordered shifter, TCU, domiworks adapter and bits and pieces and a new 25row setrab oil cooler/spal fan setup.
  • Like 3
On 1/9/2022 at 7:48 PM, admS15 said:
That's a bit of shit luck there. I like where you're going with the 8HP. What are you going to use to control it?
Should be fun, hopefully goes together alright. I went with the TurboLamik TCU. Lots of guys ive talked to have run GCU and nothing but problems and switched to TCU. So hopefully be pretty straight forward and get it running nice. Everyone reckons its basically a plug and play unit with minimal tuning needed. They preconfigure it to your car before its sent out.
  • Like 1
Yeah, good call. I was going to say whatever you do make sure you don't use the htg GCU. Obviously you've heard and probably seen the same stuff I have. Hope it all goes well, that will be an awesome setup and make your car next level.
  • Like 1
Had some bits and pieces arrive in the mail over the last week.
BMW shifter out of a 6 series, new setrab 25 row cooler with spal, and I ordered new center console and shifter surround as I had cut my factory one up to fit the glide shifter so I sold it with my box.
Domiworks gearbox adapter is currently being made up, will have to get a custom flexplate made up as we can't get it to fit with a yellaterra flexplate without making the bellhousing adapter wider. So that and the install board and 8hp connector should be here in the next couple of weeks.
Also put new brake lines in a few weeks back now. Wanted to clean up the bay a bit more and hide them/mount them a bit better. Just hoping the route I've taken doesnt get heated up too much by the dump pipe.
Glide is also now out and waiting to be picked up by the new owner in a couple of weeks when I get back from Fraser. Hopefully when I get back ill get cracking on interior and mounting the new shifter.
  • Like 3
Is there a particular model of the box that is recommended and where are you sourcing it from? This has me pretty interested as well for my 1JZ (currently with the standard A343 box). Also very interested to see how the turbolamik TCU goes. Is Tuned Performance assisting with this too?
  • 2 months later...
Not a lot happening lately, have been away for work a little bit and now covid the last week. I got out into the shed on wednesday and finished pulling my block down. The new block Ive gotta get an oxy onto the crank gear as its about rusted on. Will be dropping the head and block/s down to builders hopefully this week coming and get some more progress going.
New Kelford cams arrived and also got some CA625 head studs to beef it up a little.
I ordered some gearbox adapter parts as well that arrived a week and a half ago from HPR Tuning in Norway! For you other guys looking at doing this swap definitely talk to Helge from HPR about getting yourself a bolt in 8HP kit! It came with everything that I needed which worked out awesome and save some time custom making stuff up. The quality of products is second to none and will be worth every bit once its bolted all up :)
Have got some pics below of a bit of billet goodness 😍
Their billet oil pan, comes with gasket and new modified filter to suit the new extended pan.
The R33 bolt in kit came with the bell housing adapter, flywheel, trans crossmember, gearbox mount and bushes and I optioned in the driveshaft adapter. Saved me using a stock flexplate with an adapter behind it to go to the converter or getting a custom one made up.
Last bits are the oil cooler adapter and the install board and cover instead of soldering wire in the mekatronics unit.
Still need to order the TurboLamik. Not sure if anyone watches zero to 60 on youtube but their swap gets me keeen!
  • Like 6
The 8HP gearbox is amazing so will be super interesting to see how it goes in a Skyline.  I've got the ZF in my Amarok and they're in all of the high end stuff at work (Touareg, Audi Q5, Q7, Q8, etc, etc) and it's phenominal in those.  It's probably the best transmission shifts at full noise I've ever experienced.  Even flat to the floor the shifts are perfect every time.  Very predictable.  It would 100% be my choice if I decided to do something on mine or any other conversion.  Would be awesome in an old school cruiser (Mustang/Camaro/any big Amaerican barge) converted to RB with the ZF.  Would be super nice just to Sunday drive.
  • Like 2
On 4/13/2022 at 7:18 AM, Looney_Head said:
sucks about the covid, but man those parts are nice. would you be comfortable sharing what the swap ends up costing you? i have been dreaming of DSG/latest auto goodness
Yeah for sure! I'm predicting it to be around the 12-13k mark in the car driving. That's with me doing all the work, ie: install, wiring, lines, mounting etc. Still undecided what I'm going to do for a tailshaft yet, go to a full custom one piece item or mod a factory shaft to suit. Would be nice to get something thats a bit lighter and stronger under there.
Just about finished up a harness for an R31 Skyline RB30, Haltech Elite 750. Just waiting on a couple of connectors to turn up. Full Tefzel, Raychem DR-25 "street" harness. Turned out pretty nice, makes me excited to go all out building my own one.
Also got the crank pulled out of the new block today. Oxy wasn't able to budge the crank gear at all so we had to resort to drilling and splitting the gear to get it off. So block will be getting dropped off tomorrow to be machined for the billet mains and girdle. Once that's done off to my engine builder for machining/resin/assembly. Head will also get dropped off to get checked over, clearance for new cams and setting up clearances. Probably get a light resurface to get it perfect to go back on. Should have it all back in the next month or so then onto sourcing a box and TCU.
Forgot to mention I also picked up a new trigger kit, black and also 12T crank trigger. So my old one will get put up for sale soon along with my Link G4+ plugin ECU. If anyones interested shoot me a PM!
  • Like 2
Geez man, not playing around here anymore are you? I remember how this all started, just another GTST with some simple smart mods. It performed brilliantly for what it was, now it's one of, if not the 'BEST' GTST build around and I know there's many. Very envious dude, hat tipped in your direction.
@Dose Pipe Sutututu I think you need to rethink the samsonas and do one of these since your car isn't a turd any more. Hat tip to le shitbok too.
  • Like 2
  • Thanks 1
  • Haha 1
On 14/04/2022 at 6:01 PM, Dose Pipe Sutututu said:
@admS15 don't worry brother, Mr @klutched here as started his brain washing exercise with me.
I still would prefer someone swap me their M3 LCI for my R33 🥲
Me too, unfortunately I think that's a pipe dream 😥 The 33 will have to do.
  • Sad 1
Plenty of clapped out R33s listed for $30k+ (minus the 1st one, that's not bad):
https://www.carsales.com.au/cars/nissan/skyline/r33-series/coupe-bodystyle/?sort=Price
There's hope for us autistic R33 GTS-t owners.
That's so retarded. Most of those would of been 7-12k cars a few years back. What a time to own a 33. 25k would of got you a mint 33 GTR. Need time machine and flux capacitor.
  • Haha 2
I paid $5k for my R33 S2 with ABS and all the factory parts (even wheels) thrown into the boot and back seat.
Unheard of now.
If I knew back then they would be worth $30k now, would have picked up 10x of them and find someone that owns a farm that's willing to hire out floorspace.
  • Like 1
  • Haha 1
  • 1 month later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
