So rolls didnt happen. Got my car all done, aircon regassed, alignment, wheels balanced. Took it home to check everything the next morning, opened the radiator and there was some oil in the rad cap. Dropped the oil and there wasnt any water so all was good. Dropped the rad and it was a bit of a milkshake party. End up pulling the motor out that night. Still not sure where the oil was pushing into the water. Will get the head all checked out and decided to sell my cams and go to a set of kelford 270/274in 280ex 10.5mm lift. The block had a couple of cracks on the deck but nothing that I could see would mix the oil into the water.
Motors now stripped down, just need to pick up another block and take it to my builder and get it all checked/machined/assembled. New cams should be here sometime this week so I'll be able to send the head away to get checked and setup for the new cams.
I have also sold my powerglide in order to fund a zf 8hp swap with goals to make the car more streetable and comfy to drive while still being able to maintain some drag racing functionality. We'll get the car back up and running and leave it on wastegate and focus on getting the box setup perfectly then we will add some power to it and see how it goes. Goal is to just drive it a lot more and be able to take my family out in it and cruise on the highway in 8th gear at 2000rpm while remaining fairly quiet. I have ordered shifter, TCU, domiworks adapter and bits and pieces and a new 25row setrab oil cooler/spal fan setup.
  • Like 3
On 1/9/2022 at 7:48 PM, admS15 said:
That's a bit of shit luck there. I like where you're going with the 8HP. What are you going to use to control it?
Should be fun, hopefully goes together alright. I went with the TurboLamik TCU. Lots of guys ive talked to have run GCU and nothing but problems and switched to TCU. So hopefully be pretty straight forward and get it running nice. Everyone reckons its basically a plug and play unit with minimal tuning needed. They preconfigure it to your car before its sent out.
  • Like 1
Yeah, good call. I was going to say whatever you do make sure you don't use the htg GCU. Obviously you've heard and probably seen the same stuff I have. Hope it all goes well, that will be an awesome setup and make your car next level.
  • Like 1
Had some bits and pieces arrive in the mail over the last week.
BMW shifter out of a 6 series, new setrab 25 row cooler with spal, and I ordered new center console and shifter surround as I had cut my factory one up to fit the glide shifter so I sold it with my box.
Domiworks gearbox adapter is currently being made up, will have to get a custom flexplate made up as we can't get it to fit with a yellaterra flexplate without making the bellhousing adapter wider. So that and the install board and 8hp connector should be here in the next couple of weeks.
Also put new brake lines in a few weeks back now. Wanted to clean up the bay a bit more and hide them/mount them a bit better. Just hoping the route I've taken doesnt get heated up too much by the dump pipe.
Glide is also now out and waiting to be picked up by the new owner in a couple of weeks when I get back from Fraser. Hopefully when I get back ill get cracking on interior and mounting the new shifter.
  • Like 3
Is there a particular model of the box that is recommended and where are you sourcing it from? This has me pretty interested as well for my 1JZ (currently with the standard A343 box). Also very interested to see how the turbolamik TCU goes. Is Tuned Performance assisting with this too?
  • 2 months later...
Not a lot happening lately, have been away for work a little bit and now covid the last week. I got out into the shed on wednesday and finished pulling my block down. The new block Ive gotta get an oxy onto the crank gear as its about rusted on. Will be dropping the head and block/s down to builders hopefully this week coming and get some more progress going.
New Kelford cams arrived and also got some CA625 head studs to beef it up a little.
I ordered some gearbox adapter parts as well that arrived a week and a half ago from HPR Tuning in Norway! For you other guys looking at doing this swap definitely talk to Helge from HPR about getting yourself a bolt in 8HP kit! It came with everything that I needed which worked out awesome and save some time custom making stuff up. The quality of products is second to none and will be worth every bit once its bolted all up :)
Have got some pics below of a bit of billet goodness 😍
Their billet oil pan, comes with gasket and new modified filter to suit the new extended pan.
The R33 bolt in kit came with the bell housing adapter, flywheel, trans crossmember, gearbox mount and bushes and I optioned in the driveshaft adapter. Saved me using a stock flexplate with an adapter behind it to go to the converter or getting a custom one made up.
Last bits are the oil cooler adapter and the install board and cover instead of soldering wire in the mekatronics unit.
Still need to order the TurboLamik. Not sure if anyone watches zero to 60 on youtube but their swap gets me keeen!
  • Like 6
The 8HP gearbox is amazing so will be super interesting to see how it goes in a Skyline.  I've got the ZF in my Amarok and they're in all of the high end stuff at work (Touareg, Audi Q5, Q7, Q8, etc, etc) and it's phenominal in those.  It's probably the best transmission shifts at full noise I've ever experienced.  Even flat to the floor the shifts are perfect every time.  Very predictable.  It would 100% be my choice if I decided to do something on mine or any other conversion.  Would be awesome in an old school cruiser (Mustang/Camaro/any big Amaerican barge) converted to RB with the ZF.  Would be super nice just to Sunday drive.
  • Like 2
On 4/13/2022 at 7:18 AM, Looney_Head said:
sucks about the covid, but man those parts are nice. would you be comfortable sharing what the swap ends up costing you? i have been dreaming of DSG/latest auto goodness
Yeah for sure! I'm predicting it to be around the 12-13k mark in the car driving. That's with me doing all the work, ie: install, wiring, lines, mounting etc. Still undecided what I'm going to do for a tailshaft yet, go to a full custom one piece item or mod a factory shaft to suit. Would be nice to get something thats a bit lighter and stronger under there.
Just about finished up a harness for an R31 Skyline RB30, Haltech Elite 750. Just waiting on a couple of connectors to turn up. Full Tefzel, Raychem DR-25 "street" harness. Turned out pretty nice, makes me excited to go all out building my own one.
Also got the crank pulled out of the new block today. Oxy wasn't able to budge the crank gear at all so we had to resort to drilling and splitting the gear to get it off. So block will be getting dropped off tomorrow to be machined for the billet mains and girdle. Once that's done off to my engine builder for machining/resin/assembly. Head will also get dropped off to get checked over, clearance for new cams and setting up clearances. Probably get a light resurface to get it perfect to go back on. Should have it all back in the next month or so then onto sourcing a box and TCU.
Forgot to mention I also picked up a new trigger kit, black and also 12T crank trigger. So my old one will get put up for sale soon along with my Link G4+ plugin ECU. If anyones interested shoot me a PM!
  • Like 2
Geez man, not playing around here anymore are you? I remember how this all started, just another GTST with some simple smart mods. It performed brilliantly for what it was, now it's one of, if not the 'BEST' GTST build around and I know there's many. Very envious dude, hat tipped in your direction.
@Dose Pipe Sutututu I think you need to rethink the samsonas and do one of these since your car isn't a turd any more. Hat tip to le shitbok too.
  • Like 2
  • Thanks 1
  • Haha 1
On 14/04/2022 at 6:01 PM, Dose Pipe Sutututu said:
@admS15 don't worry brother, Mr @klutched here as started his brain washing exercise with me.
I still would prefer someone swap me their M3 LCI for my R33 🥲
Me too, unfortunately I think that's a pipe dream 😥 The 33 will have to do.
  • Sad 1
Plenty of clapped out R33s listed for $30k+ (minus the 1st one, that's not bad):
https://www.carsales.com.au/cars/nissan/skyline/r33-series/coupe-bodystyle/?sort=Price
There's hope for us autistic R33 GTS-t owners.
That's so retarded. Most of those would of been 7-12k cars a few years back. What a time to own a 33. 25k would of got you a mint 33 GTR. Need time machine and flux capacitor.
  • Haha 2
I paid $5k for my R33 S2 with ABS and all the factory parts (even wheels) thrown into the boot and back seat.
Unheard of now.
If I knew back then they would be worth $30k now, would have picked up 10x of them and find someone that owns a farm that's willing to hire out floorspace.
  • Like 1
  • Haha 1
  • 1 month later...
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
