3 minutes ago, sneakey pete said:
Interesting to see how that goes. Have heard of people having extreme EGT problems with high comp
Prob needs to be factored in with cam duration and a decent rear housing!
My r32 is about to get a rebuild. Will be going the precision rout. Either 6266 or 6466. More likely the later. Either way, will post results in the future for some comparisons. Chasing 500awkw+. Awesome thread. Cheers gents.
Curious. This is a thread about Borg Warner EFRs and just had a quick skim through and you don't have appeared to have made any previous comments in here so to make give it some current and future context can you share why you chose it relevant to this thread that you post that you have decided to buy turbo which has nothing to do with this thread and how it might pertain to this? Do you intend on later upgrading to an EFR?
  • Like 3
Hi,
How much is spool difference between 8376 and 8375 with the same hotside like .91 ar ? +- :P
Maybe some one compare 8376 with another one?
Edited by Snara
BW updated the wheel aero on the SXE turbos.  the 8375 is their older turbo with 75.99mm turbine and 270 thrust.  (probably should have called it 8376 all along)  -- SXE 8376 is their new version of this turbo and is now 76.2mm with 360 thrust and EFR blade aero (with corresponding bump in turbine efficiency).  Using the same housing A/R an SXE can spool a little earlier due to the turbine aero - but the more aggressive compressor wheel makes the turbos spool almost identically.  Attached is a photo of the old turbine wheel on left, new SXE on right.  We have these in stock at a healthy discount right now if you need one
Edited by Full-Race Geoff
I can make it relevant Mr Lith, he can buy my PT6266 CEA Gen 2 next year and I will get the EFR 8374 , lol
People keep asking for comparisons to other turbos. Precision turbos are the main competition to Borgwarner. The turbo I'm choosing is one that people look at when they look at the 8374. I'm in no way trashing the 8374. It seems like a great product. But it is brand new and hasn't had time to be proven yet. Looking at threads overseas, if the turbine wheel is damaged you will up for a new turbo. There are reports of these turbos leaking. Despite great dyno results, most of the drag records right now are being set with precision turbos. Dyno is a tuning tool. MPH, I believe is the true measure of power. I simply chose a turbo which has been tried and tested. The new turbos are air cooled so no leaks, ever. Parts are easy to get and units are easy to repair. This only my opinion and in time I may very well be proven wrong. As I said before, great thread.
  • Confused 1
Geoff, can you confirm any sort of update with the 8374. I haven't seen any "update/gen2/revised" from the get go?
6 minutes ago, khezz said:
Not the current version of them.
What exactly has been "updated"?
I remember seeing a few people talk about lack of compressor maps for the BW range (at least I think), but anyway, this is a good tool for picking the right turbo for your application. Though a lot of the required info a bit too specific for most peoples engines
Tutorials and FAQ down the bottom
http://www.turbos.bwauto.com/aftermarket/matchbot
Fair call sneaky pete. I seem to be offending people for choosing a precision turbo. People here are asking for comparisons to other turbos, I'm more then happy to provide one. You ask me why I didn't choose the 8374, I explained. I said that this was my opinion only. If this is an "all hail Efr thread" not a problem. I'm sure the product deserves the praise it gets. I was just offering a comparison that people are asking for.
  • Like 2
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
