Borg Warner EFR Series Turbo's V 2.0
Piggaz
16 hours ago, Nismo 3.2ish said:
Here is the E65 Dyno run ,looking good
I have put this in my thread but it might be of interest to those of you that understand, me ?
Just to add something the Tuner said.
I would not read into the dyno response figures at low RPM too much as I had to run at a much higher ramp rate that I would like due to the torque splitting playing havoc on the dyno.  This is very common for GTR’s on dynos when the power output is very high.  The best comparison is to see how long it takes to reach x boost from x boost.  Not just RPM.  I can literally put the foot down and have boost on demand in your car with this turbo.  It is very sharp.
I'd be more worried about the rpm vs speed relationship and the fact the run wasn't done in a 1:1 gear ratio...
Turning over at 6000rpm?
I would assume that's because it is tuned to turbine wheel speed and tapering off boost to keep it under the threshold.
  • Like 1
Can't remember what has been said in here, but the boost peaks and then rolls off - not because the turbo had nothing else in it, but because the brief was more about low down/midrange and reliability as opposed to give it all she's got capn' - as far as I know.    This is definitely not maxed out at any point of the rev range, and I'd say if it had a flat boost curve it'd look less like it rolls over.
Pretty sure it's only around 20psi at peak rpm.
Edited by Lithium
  • Like 1
16 minutes ago, Mick_o said:
I actually believe it was 24 or 25psi tapering off to 20 to keep turbo speeds at 120000rpm.
yes, 25 to 20 on the E65 runs I think. I asked to day for a graph with the psi details ?
20 on the pump I think , maybe 21
17 minutes ago, Nismo 3.2ish said:
Short test run today , looks pretty good.
As you can see, just starts going at 3K and keeps going
8374 first run after tune.mp4
Looks good, mate!   In 2nd gear it looks like it's got GOOD boost by 3500rpm without trying too hard, and picks up hard when shifting in the 6000rpm range.
2 minutes ago, Nismo 3.2ish said:
Just running under 3k from to have a look at it and went better from idle in 1st as well, the idle is now 900rpm , not 1200 and hunting :)
I thought it looked pretty tough over 3k , very linear as well.
Wheels  are you entering a tractor pull contest?
2 hours ago, HarrisRacing said:
Really nice. What are the specs on the engine (I totally forgot).
3.2 Nitto Stroker
HKS Vcam step 2   with UE 260  10.85 Exhaust
EFR8374 , 4" dump into 3 1/2 to tail
8:5 CR
And all the stuff to make it all work together .
I will be giving it my first runaround noon today :)
  • Like 1
Had a quick run when the car was dropped off yesterday and could feel the difference without smashing it hard.
I went for a run early this morning and it is a different machine to drive , first I gave it some up to from idle 7500 and it felt like it was hard all the way after 3200 and got there pretty quickly from idle, felt great.
Then I did some changes at 5000rpm and it was on boost through 1,2,3,4 and 5th had to stop
Next I did the same at 4000rpm 1,2,3 and 4th to see what happen, it was just about ready to fly in another 300rpm ish from each change, mad!
You can dive it anywhere in 6th gear in a 60 , 80 or 100kph zone without changing back on any hill , the only time I had to change was on the 35kph bends going up to a step incline , that torque is just so good in a street car , especially if you want to relax a bit
I would say it is very close to 900rpm better while driving it in any gear if you want to get it going. it really starts to get going at 3000 and hard just after that :wub:
From my experience , in my car it smashed the 6266 everywhere as a driving experience.
Happy camper, you bet , it is a great car to drive at any speed and just feels alive everywhere
  • Like 5
That is mega impressive, Not necessarily too surprising but still awesome that it is performing like that and it sounds like something that finally gives you the GTR experience you had been looking for.  Long expensive and frustrating journey at times but finally there!
Congrats on building a beast, hope there are many fun drives on The horizon with the new found power, response and general road manners:)    cheers for the update, too!
  • Like 2
Thanks mate, it has been a while but I finally got the car going how I wanted it to go and its a fun ride
  • Like 1
53 minutes ago, sneakey pete said:
Makes me excited to get mine.
Soon hopefully :(
You will love it :wub:
Paul and Mick could explain it better in car bloke talk, they had 25klm each down a nice bit of driving road, well except for the pot holes , lol
    • Go to SP mufflers and get the muffler of size you want and make a nice mid muffler. It's about that simple! I have 2x 3.5 Magnaflow straight through Mufflers and while it's pretty loud with the Varex open, it's quiet enough with the Varex closed. You can also buy off the shelf Magnaflow straight through mufflers as well. You also have a turbo to quiet the car down too. Don't overthink it. Buy my extra Magnaflow muffler sitting on a shelf doing nothing (buy it new, ignore this part)
    • Centre-offset muffler under the floor, same as stock. Just....3.5". The change from straight pipe there to centre-offset will mean that you need to remake some of the pipe (add a bend or two).
    • Hey guys. So my R34 GTT has a custom 3.5” exhaust (done by previous owner) with a high flowing cat, and then just a Varex cannon muffler on the back. The car does drone alot and is really loud even on highway driving just cruising, as you can imagine due to the Varex muffler basically being a straight through with the valve open. As much as i love a loud RB, it can be a bit much with no other muffling in line and just driving casually. I wanted to lower the volume output on the exhaust a bit, as well as remove the drone (probably a way to do both at once), and was going to do it all myself as I am a fabricator and have done exhaust work in the past, so the fab work isnt my issue, im just not sure on the right product or type of product to use to get the job done, and i doubt an exhaust shop would be wanting to help me as they wont be making any money from helping me, unless they supplied the product? Anyway any help or guidance in best way to approach this would be awesome   Thanks in advance
    • Meh, whilst the Honda is a "really" good car and has potential if you want to drop coin on, it was uninspiring for me to look at, but, it did serve its purpose and is now in the boys hands, his happy, his girl is happy, as she wasn't to keen on the noisy old Patrol, and most importantly, the Minister for War and Finances is extremely happy that her "little baby boy" (6'2 nugget who is currently training to be a copper, which will make 3 coppers in the immediate "circle of trust") has a well sorted reliable car that doesn't guzzle diesel Me, I'm more than happy with the NC MX5 that I replaced it with, it's a fun little car that I like looking at, like driving, and yes..... I do like the fact that the maintenance and modifications that I have done/will do are plentiful and relatively cheap, well........ while staying naturally aspirated slow that is, and that's all I really need for a fun little daily, I can rev the 5hit out of it rowing through the gears and never really break the speed limit  In saying that wicked word, "modifications", I've already ordered something for some noise and an additional "3 ish" horse powers, or whatever it gives, in the form of a header, and, a new set of "cheapo" BC coilovers that are already sitting in the shed waiting to get put in, I had the same BC's in my old NB and found they were fine for the street, hwy, and the occasional track days I did in it, they have 6kg front and 4kg rear springs which is about 10% stiffer than the stock springs which I found worked well for their price  I've also already been in touch with MX5 Mania in Dural, so once the header is on it will get a ECUTek RaceROM tune there (I cannot rev match for 5hit, and I loved the RaceROM rev match and FFS in my old 86 "RIP") In other, maintenance news, I put some new sparkler plugs in it, and have a new set of DBA Street series pads to put in over the next day or so, I'm running the DBA street series in the SS and Honda and really like them, they work great and are not dusty at all I've also booked in a few days leave over this weekend to give me 4 days weekend do some paint correction and give the leather seats some conditioning and interior some Bissell and steam cleaning OCD lovin', the carpet and interior looks clean, but from my experience with the Bissell IRT carpet, and the steam cleaner IRT trim, looks can be deceiving I've also found that finding a detachable hard top is proving problematic, the main reason why I didn't like the NC initially was the power retractable hard top that I seen them with gave the roof line a weird look, the detachable roof though looks good, and is a same shape as a NA/NB hard top, similar, but unfortunately not the same as it has different fixture point on the front, so fitting a easy to get NA/NB detachable hard top is no bueno New Old cars are fun, cleaning, hunting and playing around brings much joy How are your beasties going? Do you still have the Skyline with the LS???, or Barra??? that you were playing with
