2 hours ago, Dose Pipe Sutututu said:
^ yep!
then buy proper tyres, a proper LSD, proper suspension arms to fix up the crappy Nissan rear geometry.. If you can't even put 200kW down to the ground, don't bother with power upgrades.
But if you're single pegging everywhere, who cares brah! 300kW uleh.
  • Like 1
On 9/16/2016 at 10:50 AM, Dose Pipe Sutututu said:
^ yep!
The later model 34 GTTs have a Helical Diff yea? Is it worth the upgrade providing this is in a healthy condition?
I do plan to take her to the track, I'm assuming a true 1.5 way would be better...
Edited by macca911
For street, a helical is pretty much the nicest diff.
For track, a proper mechanical diff is better.  Especially if you have really high roll stiffness - where you may lift the inside rear wheel off the ground - or if you tend to hit kerbs hard enough to do the same.  Getting a wheel up instantly converts a helical into an open diff.
Also S2 R34 helical diffs are like hen's teeth and if you find one I would prefer you let me buy it.  Or at least the 5 bolt stub axles from it!
Edited by GTSBoy
On 9/16/2016 at 1:53 AM, hypergear said:
lets say. I can get you 3582's power with better then 3076's response. and much cheaper in price.
Hypergear, I'm listening... Would this be something like the Atr45sat?
Internal or external gate?
Cheers,
Thats the latest ATR45SAT RV2 model in ceramic ball bearing center. Is maxed at 330rwkws on 22psi p98 fuel internally gated Bolton, 20psi by 3650rpm, unopened neo motor.  Run that externally gated e85 it will be making around 400rwkws region. Check my fb or dyno sheet section for result.
  • Like 3
  • 1 year later...
Gents,
It's been some time since my last post.
The car has been finished and it made a super responsive 625rwhp and 680nm (e85)
I went with the following setup:
  • JHH Built RB25 Neo
  • EFR BW 7670 1.05 TS
  • 6boost Manifold with twin gates.
  • 2000cc Bosch Injectors
  • Haltech Platinum Pro
  • Hypertune Plenum + TB
  • PWR Intercooler and Oil Cooler
I can't recommend GT Auto Garage at Slacks Creek enough.
Their attention to detail in both fabrication and tuning is fantastic!
Still running the stock gearbox...
Cheers,
  • Like 3
It turns out every car I drove after mine felt like an absolute dog.
The EFR smashes the GTX3071 in every aspect.
I have unrealistic expectations for response it would appear relative to 100% of RB's ever built. I would assume that a 2.5 with a 7670 would be laggy, or at least laggier than mine. Still going to be better than anything else bolted to a 2.5.
The result does backup my thinking on the matter, that the 7670 is actually a pretty big turbo and is more a 450kw turbo than a 350kw turbo that people seem to consider it to be. Would be curious to see if there is speed sensor data as 466rwkw is really up there.
On 7/3/2018 at 12:04 PM, macca911 said:
Gents,
Cheers,
Very nice!  Can you please share the dyno plot?  The peak power is solid, but not the most interesting part of that setup :)
Kinkstaah Unfortunately I don't have a speed sensor installed. It's coming...
I have to agree, it must be pushing the limits!!
KiwiRS4TIt wasn't intentional... I've now got concerns for the gearbox etc... Matter of time haha.
E85 run attached. I believe the dip at 5400 would be VVT... Please correct me if I'm wrong.
Unfortunately, I'm in the US and only have the 625hp/640nm run photo on me. You'll get the idea though.
The final power run video is on the GT Auto FB page.
As always, bugs to iron out and more mods to do.
At this stage, I've planned as far as brakes and an accusump setup in the coming weeks...
  • Like 1
I would log your RPM vs. time, I wonder if the VCT turning off is causing some form of timing belt slap/vibration thus causing the CAS to spaz out.
That would explain the harsh dip
  • Like 1
The dyno run attached does look quite a bit like it could be VVT turning off too early, I'm assuming that's sorted now?
Saw a post on NZ Wiring's workshop page of a very similar setup/workshop which upgraded to an NZ Wiring CAS setup on an RB25 Neo recently, wasn't you by any chance?  Very solid delivery for an RB25 making that kind of power, though.  Should be a fun drive :)
  • Like 1
Nah, not me. I'll take a look though!
Not sorted yet... Mainly due to work commitments. I'll aim to spend some time on it starting next week.
Edited by macca911
(y) This is the post that got my attention btw: https://www.facebook.com/nzwiring/photos/a.263208990533912.1073741827.263205613867583/915378341983637/?type=3&theater
  • Like 1
big power, noisy valvetrain and Nissan's high resolution optical sensor (CAS) never works out well haha
VCT "shouldn't" be giving you a massive dip, I dare say (without any data) that there may be triggering issues
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
