4 hours ago, Adzmax said:
I picked up an R200 with a 4.4 LSD on the weekend, I'll strip this down and rebuild it along with the rest of the rear end in the coming weeks.
7 Days for a update bruh, whats happening :P
In all seriousness, take your time, build is looking awesome :D
7 hours ago, jmknights93 said:
Such an awesome thread. Loving these updates :)
Thanks mate!
Some goodies we purchased in Japan at Nostelgic 2 Day arrived today (no pun intended), a set of S.E.V Marchal headlights.
  • Like 2
It's been a pretty crazy few weeks so not a lot happening on the car front, hoping to reassemble and pain the GTR grill this weekend though. I can't for the life of me find the paint sample we made up so I had to get a mate to send me down his colour chips for matching, no paint codes available for this stuff unfortunately.
I was going though some boxes from my trip to Japan in Feb this year and found these goodies. Some door handles, a GTR style gear know, NOS badges, water heater seal and stainless trim for the centre console.
Also a whole bunch of stickers for the car, it's the little details that make the difference! :)
  • Like 2
So a pretty major development this week, Lachlan Fowler at Les Collins Racing had a fully built 3.3ltr L series short block for sale which I've purchased. He's decided to go down the full billet crank race spec path meaning the built bottom end is no longer needed. I'll supply my own P90 head to the builder to be ported, polished and rebuilt. The motor should be good for 350hp and 280ft'lbs of torque with the right head, cam and induction.
Short motor specs are:
  • L28 3.3ltr short engine.
  • 89mm bore x 89mm stoke = 3322cc
  • Engineered by Les Collins
  • F54 block. Acid dipped, 1/2 grout fill, sonic tested & offset bored to 89mm & finial diamond honed to exact clearance.
  • Deck milled parallel to crank tunnel centreline.
  • Clearanced crankcase, de-burred & painted in Gyptal.
  • New gallery plugs. Blanked oil pressure relief port.
  • Standard sump & pickup (to be replaced with Kameari pickup)
  • Modified 89mm stroke crankshaft, oil gallery plugs tapped & plugged.
  • Custom CNC billet steel 8.8kg flywheel to suit crank (no clutch assy).
  • 137mm I-beam connecting rods with ARP2000 rod bolts.
  • Custom SPS 89mm forged pistons – designed to work with a P90 head.
  • New timing chain guides & new Kameari HD timing chain.
  • New OEM front timing cover (de-burred, polished & water-jet blasted) fitted with replated bolts.
  • New Water pump.
At this stage I'm looking towards injection as the 44 Mikuni carbs I have just wont be big enough and would limit the motor to around 280hp. The other option is 47mm OER carbs but Jenvey make a 47mm heritage DCOE twin body with the injectors hidden in the body. Heritage look with modern features. I'll need to look at a fuel tank conversion using EFI hardware's EFI conversion kit and consider an ECU, perhaps Motec M800 or a Haltec equivalent.
Not sure who will complete the head work and engine but at this stage I'm looking at either Peter McDonnell or Les Collins Racing, both are true professionals and will do a great job.
Here are some shots of the motor before it will be torn down:
  • Like 2
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
