What a day, been moving shit to the in-laws, cleaning the house, mowed lawn, planted a bunch of flowers. Then sorted out shit box for tomorrow, bleed brakes, installed new Intima pads (test compound), loaded up car with shit and ready!
Rotors look a bit cooked, I managed to crumble the Intima Type-D v2.0.
@iruvyouskyrine they're 57S :)
  • Like 1
Dose knows I'm good for the $$
I've had to pay him for his services before.... ?
Rotors do look average.
Edited by ActionDan
Motor seized heading back to Sydney. Had full oil pressure, no over heating.
Was tapping a bit on the way home but just thought maybe lifters.
Car did hit the engine protection a few times on the track though for low oil pressure around big bends.
Now waiting for my mate to come back with a trailer on the side of the Hume Highway.
Yay?
  • Sad 7
Cheers @Duncan!
Luckily just at the on ramp to Sydney out of Sutton Forest Maccas, safe-ish spot.
Same tyres lol..
My mate did a 1m10s in it, I managed only 1m12s
well, you can't change the laws of physics; a borrowed car is always quicker than one you own.
at least it is a short walk to heatherbraes (or Maccas if that is your thing)
  • Like 2
I did crack 196 km/h down the main straight but bitches out just as the barrier stopped.
Could have possibly gone 200 km/h+
  • Like 1
Is what it is lol..
Maybe the few times the Haltech went into engine protection was a sign I should not full send it around bends on noise.
19 minutes ago, Dose Pipe Sutututu said:
Is what it is lol..
Do you have logs of the sessions where the engine protection kicked in?
I'll download them sometime during the week and we'll find out.
6 minutes ago, robbo_rb180 said:
That sucks, dry stumped billet rb30det with Samson time?
Hopefully damage isn't to bad and just needs machine work and bearings.
Haha I'm over it man, maybe new car time ?
Get that part out sale going and find a 335i coupe.
  • Like 1
Well shit ?
This is legit the 7th RB I know of thats seized this week. Just as I get my block back from the machinist. Its like the world is screaming at me to stop what I'm doing.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
