39 minutes ago, mlr said:
Looks a million bucks, noice
Having some buyer's remorse 😅
Could have went towards a depreciating M2/3/4 lol.
  • Haha 1
Fark the 3 pointed swastika pos
Or sell up now and buy a 3 pointed swastika and regret?????
The old Datsun is gold dust, any muppet with a job can own a BMW
My 2 cents is to stop treating the old girl like a dirty bitch
Not saying to not run her hard, just saying to not treat her like a dirty slart
  • Like 1
  • Haha 1
For some reason a bunch of n54 bmw videos have come up in my feed so I watched a few and f**k they have some issues.
gotta spend the value of the car every year just to keep the oil inside the engine and the engine check light off and then all the body modules start throwing trouble codes up
Don't forget WALNUT BLASTING + VANOS Issues lol
Probs still gonna buy one at some point =\
  • Thanks 1
Just saw engine nudes,
that f**king sucks dude. What size restrictors did you put in when building the engine?
Also who did the respray and rough cost? Looking to get S15 done
@niZmO_Man lol not the look I'm going for, that's too IG try hard, get likes and attract fk bois look :D
@iruvyouskyrine Good eh? lol... the bottom end I believe had 1.2 restrictors in it, however none were blocked off (this was recommended by the shop that built my bottom end). Respray wise, it ended up a bit over $15k with the guard work (F&R), glass removal, rust work, hail work, front windscreen replacement, fitting the skirts/pods, shaving off the GT-R logo on the wing, lengthening the front lip (as the Car Mate one is too short, no joke!). I did get carried away, initially it was going to be a basic respray, then nek minnit.....
  • Haha 2
Don't worry bro, in this market, with a fresh coat of paint and some rotas it's a 50k car....
  • Haha 2
How I managed to crack an AWD block in a RWD car with only a measly 407kW makes proves the NEO AWD blocks aren't unicorns 🙁
  • Confused 2
  • Sad 1
Someone tagged me in this, sad reacts only 😅
When it worked, then it didn't, then I all thought was it would have needed a simple fix, then I find the head is cactus then somehow the car gets a makeover 😅.
Then a few weeks later I find the block is cracked.
119217053_2773272086242183_6513774598418894058_n.thumb.jpg.d06e0eea3a4e5fd98fd4b47ef97fb617.jpg
  • Sad 3
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
