On 11/06/2021 at 7:09 PM, Old man 32 GTR said:
Well, I’m going back to a 2.6 based motor, just in the process of getting everything together, things getting re-furbished, coated or replaced with new where I can. Car is at the painters now, decided to paint the bay the colour of the car. Also sold my hotside so it’s being replaced with a 6 boost manifold and 68/75 turbo. I’ll also be running egt’s and getting a new engine harness . But one thing at a time 🤔
God I wish I could be bothered removing the remaining engine bay bits while the donk is out so I can paint the engine bay but I just can’t! 😂
Look forward to seeing how it comes up.
15 hours ago, Unzipped Composites said:
Ahh I see, I thought you were saying you were going back to a 2.6L. Just misunderstood what you meant by based.
Carry on then!
Oh, all good, yeah meant 2.6 block, motor is a 2.7. Can’t believe how many little things there are to do, just don’t want to miss anything while everything is apart. Currently getting the sump, cleaned, painted and clear coated, boosted getting done, clutch master getting replaced with new, brake master is new, going to get the wiper motor cleaned/soda blasted? I’m not sure, but what ever it takes to make it look new. On Tuesday I’ll be chasing around trying to get all the engine bay nuts and bolts either replaced with new or what I can’t get replaced will get zink coated. Got titanium stud kits for hotside, cold side and cam covers.
brand new genuine bolt kit for valley cover and front timing cover, new backing plate, new dipstick and tube, new blinkers, intercooler, radiator and lights. Under the car got billet fuel line brackets, all the heat shields are off to get custom ceramic coated in a matte silver, just trying to source new bolts.
and I haven’t even started the rear subframe 🤔🤪
I bought the titanium inlet and exhaust studs but they both look the same, are yours the same as well?
Haven’t received them yet, I’ll let you know when they come.
Also, if they are the same, will they work on the inlet side?
Well the spending continues as I travel further down the rabbit hole!
decided I’m doing the entire front end, so both left and right sides are coming out, getting new hubs, new bearings, new bushes, anything I can’t replace with be blasted coated before being re-fitted.
At the moment I’m trying to get the wiper motor referbished, I have sourced a new one, but it will cost me around $700 so I’ll try to get mine looking good enough to be present in my engine bay 🤣
Brett, I got my studs, we’re both same size so won’t work with factory plenum, I’m talking to John and working with him to make a set to suit factory plenum. I’ll let you know how it goes.
also I bought a rear genuine Nismo tower brace to match my Nismo front tower brace, just got to decide what colour to get them coated.
also can’t decide what to do with the AC compressor and alternator. Thinking ill paint the alternator black and maybe see if I can get the ac condenser cleaned.
ive decided I’m getting a custom power steer reservoir with an fittings and custom braided lines, will also be running a power steer cooler and fuel cooler.
here is a few parts I’ve had cleaned, the clear coated myself, did the ac condenser myself. Turned out nice
And yes got a new build plate from FPG.
  • Like 3
4 minutes ago, BK said:
Nice one. How's the Frenchy's build plate quality ? Was considering getting one done
Looks very good, I’ll have to put it next to my actual one to see how close it is. These ones are laser cut so supposed to be better then the previous ones he was doing.
I'm sure they're good. Is the Frenchy's plate stamped at all with the lettering ? As you would know the factory one is a plate with a blue coating that is laser cut purely into the blue finish. I guess what I'm getting at is would you actually pick the difference between theirs and a factory one ?
I’ll get a photo of the original and the fpg together. I’ve done it purely because the lengths I’m going to with the bay, I want everything looking mint.
I’ve just ordered new oem front hubs, bearings ball joints etc as well as a heap of oem nuts, bolts clips.
It’s amazing how fast the $$ add up.
but can’t stop now I guess 🤔
39 minutes ago, r32-25t said:
I’ve been looking at one of those blue plates myself, how long between ordering and receiving did it take?
I Orderrd it at GTR festival, but there was a delay as it was the first batch of lazer cut ones. Normal turnaround time is 2-3 weeks, I was told
  • 2 months later...
Well, I guess overdue for an update, short story, this car is killing my life! Lol Maybe more then COVID!
ive decided I’m doing the entire front end, so really just been shopping on line. Waiting on a couple more things to arrive then can push ahead with the build.
My guest room in the house is now a parts room and is just about packed to the ceiling with parts.
I’ve got new king pins, inner and outer ball joints, hubs, bearings and tie rod ends. Just got to order bushes for the front.
rear end I got new hubs bearings, bushes (a mix between white line and nismo) and building a 31 spline diff, ordered a quaife centre, got my hands on a set of 31 spline half shafts and brand new ring and pinion gear set.
I've had the sump cleaned and coated black, did buy a greddy diff hat, but it doesn’t fit! Grrr hit the extended sump, so going to use the factory hat.
Probably spent about 2k+ on new oem nuts/bolts/washers etc. As the saying goes, too much to list! Lol
sent the front diff gears to Neat gearboxes to be shot peened, once they are back will get the sump back together and put the motor completely back together and ready to put in the car.
Rear turbo housing and manifold have been ceramic coated and I had the under car heat shields done in custom matte silver finish.
Engine covers are done, most brackets have been coated, front reo was powder coated as well, re done the gearbox crossmember.
just got to do my catch can and a couple of other little things to coat.
Bought the new PRP pro trigger kit (well the top part) which runs the new sensor.
Goal for the car is still the same, although I’m feeling I’m going waaaaay over the top.
Probably will be too clean, but it’s my money, and I still plan to drive it everywhere!
looking forward to a Bathurst run!
Sorry for the delay, I was working in ACT when Sydney went into lockdown and couldn’t return home. Here’s a pic of the FPG plate
  • Like 1
  • 1 month later...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
