Garrett G Series
G30 turbine flow :
Les turbo garrett G series - Page 4 G30turbineflowmap
G35 turbine flow :
Les turbo garrett G series - Page 4 G35turbineflowmap
The compressor flow chart :
770 :
Les turbo garrett G series - Page 4 G30-770comp-map
The 900 one :
Les turbo garrett G series - Page 4 G35-900comp-map
and finally the 1050 one :
Les turbo garrett G series - Page 4 G35-1050comp-map
All were taken from ATP website so I consider these as legit but still take these with a grain of salt as they were not officially released.
Understood, and very much appreciated - thanks for sharing - that's awesome.
I'm pretty confident they are legit, btw.  Just probably weren't meant to be released yet
I've had a quick play with that data, and if I am looking at it right - the 1.01a/r G30 hotside is very comparable to the 1.05a/r EFR8374 hotside which puts things into perspective.
The .83a/r G30 hotside falls slightly short of the .82a/r GT35 hotside in flow.   I think Garrett have chosen some very nice spread of options with this range.
  • 4 weeks later...
On 12/04/2019 at 4:41 PM, Phat_Toni said:
The g25 660 with the 0.92 looks comparable to the GT3076r but seems to have the edge in turbine flow, compressor flow and spool.
g25 660 0.92 from ATS
6boost mani
I saw a post on Sinco NZ's Instagram page which made me think of you, how is your build going?  Did you end up going Sinco for the manifold or is there someone else doing similar?
1 hour ago, Skylineusa said:
This page is gold with great information. Thank you guys! Would running twin 550 be a worthwhile combo?
That's a very open ended question.  For what power target and on what kind of setup??  Do you have the budget and inclination to do all the fabrication to do twin 550s? (it's not something you'd do on stock manifolds/location).
It is the kind of setup which to justify would need a pretty solid engine spec, basically its a 1000hp turbo setup so expect the kind of lag that would come with one and expect to need to do the kind of engine and transmission development needed to support it.   If you are looking at making the typical kind of power that people go for with low mount twins then no, imho it is not worth doing.
5 minutes ago, Phat_Toni said:
I think this car was mentioned earlier in the thread. Gives a good idea as what to expect from 2 of these things....
It's worth nothing a couple of things he says which contradict each other, he implies it spools 500rpm better than the EFR9180 but then also says its all in between 6000-7000rpm which on a 2.8 is... umm... much laggier than any EFR9180 I've heard of.
It's been previously said that it's got a 500rpm wider powerband as the 660s hold on (unsurprisingly) to much higher rpm than the EFR9180 and other turbo setups they ran on it, so if you are willing to rev it to 9000+rpm then it offers the potential to give a broad delivery - as long as you aren't hoping for things to happen earlier in the rev range.
Be great to get some more data points from that car.
The twin G25-550 intrigues me as well.  They do the internal gate T2 .49 which screams bolt me on an RB26.
I've be told by a seller its not a bolt on affair though. I was not given any details other than you have a 30 year old car "dude" as to why.
The cost of them makes it a serious investment and a risk you end up with a street pig.
If not and they make 900-1000fwhp with amazing spool  ..... all the glory is yours  ......
When they released the spec sheet on the g25 I looked at them real hard. The problem I saw is they are longer than the stock turbo. There just doesn't seem to be horizontal room for them. Granted this is based off the spec sheet and not trial and error.
If we could slant them 20° from horizontal they might fit but you can't do that and expect the snail to live.
Sorry Lithium, you are correct. I should have gone into a little more detail. I was thinking for quick spool, which I understand by your reply, and looking at the map, would not be a good marriage. It looks like I will wait for the 770s to come out, and go that route.
Hypertune makes twin manifolds for the G25s, if anyone is going that route. My car is more street than track, so I really do not need that much power.
Edited by Skylineusa
I hope you mean a single 770? :o
  • Haha 1
15 hours ago, Skylineusa said:
...My car is more street than track, so I really do not need that much power.
5 hours ago, Lithium said:
I hope you mean a single 770? ?
I think that's a safe assumption.
Yeh its interesting.
I am in the process of getting rid of my HKS F-con rubbish in favour of a Link g4+ and upgrading my trigger system and fuel system at the same time.
Once done the G30-770 be on the next list to replace the -5's.
So sooner they come out the better so someone else test for me.
  • Like 3
That has potential to be a hell of a fun setup!  Hope Garrett don't take TOO long to get those out
  • Like 2
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 27th July 2024 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas  We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 14 July 2024 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk  This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Who's itching for another cruise...?? That's right! You are! And so are we! And what better cruise to run than an Old Pac Run!! So without any ado whatsoever, here are the details for you to save: Date: Saturday 22nd June 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:00pm for a 7:30pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://www.google.com.au/maps/dir/Cowan+Rest+Area+-+Truck+Stop,+Cowan+NSW+2081/mcdonalds+gosford/@-33.5145054,151.1875996,11z/data=!4m39!4m38!1m30!1m1!1s0x6b0d50be6b302f7b:0x52a920c40b292919!2m2!1d151.1590113!2d-33.6115097!3m4!1m2!1d151.1632842!2d-33.6047898!3s0x6b0d509345312641:0xb510e358747a5332!3m4!1m2!1d151.2008176!2d-33.5274838!3s0x6b0d4e5adac43725:0x611c05fee203a98a!3m4!1m2!1d151.1925869!2d-33.4598502!3s0x6b0d4926bcb9e627:0xd95f510d7f39b402!3m4!1m2!1d151.2072744!2d-33.4523186!3s0x6b0d49138231a221:0xaf20c78b79e9db5a!3m4!1m2!1d151.2318957!2d-33.4309951!3s0x6b0d4989b4996d83:0xeae9af9b71739b59!1m5!1m1!1s0x6b0d4aaa920441e5:0x33f1be63f4680e2f!2m2!1d151.32463!2d-33.4269!3e0?entry=ttu Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Thanks, I'll have to cobble something like sonicii did, will report back
    • Agree! I still believe I have the quietest 400kW+ R33 in Australia.
