Hey guys, so im currently in the market looking for a car.
Ive been offered a NA R32, with 220xxx. Seller said no leaks or issues with the car other than minor paint fade. However, the car has 220xxx kms and im looking to use it as a daily. Apparently it is the orginial rb25de and hasn't been engine swapped. (How do i know this for certain?) Is it a good idea to do this? Also if the car is defected, i've seen horror stories with people having to sell them off as track cars (Why is that?) Please help me decide. He wants 7k ono, but im not sure if its the best decision tbh.
Cheers
Edited by james1999
https://www.sau.com.au/forums/topic/473288-buying-a-na-r32-as-a-daily/
Actually, I will stand up and say that an R32 GTS25 wouldn't be a bad daily.  Certainly not fast, and for that reason may not have been thrashed.  But if it shows any signs of being in anything other than really great condition, then do not pass go, do not exchange $200 for it.  Simply not worth the investment.  For $4k (its absolute max value) you could get something less than half as old with many fewer miles done.
Full admission.....I have a sneaking want to put a supercharger on an RB25 R32.  But would need a diff and brakes and suspension and turn something supposedly cheap into a dollar pit.
  • Like 1
Would have to be immaculate. RB25DE R32 would be a great daily.
But as above, be prepared to wrench or spend money on it, all cars require maintenance, especially older ones.
People sell defected cars as track only because their car is unroadworthy and too expensive to bring back to roadworthy condition.
  • Like 1
5 minutes ago, Dose Pipe Sutututu said:
for $7k I would go buy a Mazda 3 BK SP23 or even Sports MAXX
Light years ahead of the R32 RB20DE, safer, quieter, faster, everything better, dual zone climate control.
Yuh, but this one is at least an RB25, so it will at least have enough torque to drive away from a set of traffic lights faster than a 3 yr old on a tricycle.  With a set of cams and decent exhaust, they sound alright and could be a bit of fun.  Just not fast.
Here’s is my advice to a young lad.
Buy a car for 2000
Buy 5 diamond rings worth 1000 each
give one to the sexiest chick you meet . It is a bold move and shows you are serious . You still have 4 spares.
Surely you will bag a hot chick with this technique
hopefully she has a nice car
Buy a car for 2000
Buy a car for 2000
Agreed 2k car, balance on coke and hookers. Wait wut?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
