I’m planning my RB28 build since the engine now isn’t at the condition I want it to be at.
I will only use this car mostly for street and occasionally track days, therefore I want it to be responsive and stealth. My target is around 700whp .
Here is my wish list,
N1 Block
Borg Warner EFR 8374 1.05a/r hotside
Garage Whifbitz T4 Twin wastegate Twin Scroll Manifold
Twin Turbosmart Compgate 40mm external Wastegates
NITTO's RB26DETT 2.8Ltr Stroker Kit
Tomei 1.2mm Headgasket
Tomei Oil Pump
King Bearings
ARP Custom Age 625 Plus Head Stuts
Tomei Procam 260Degree 10.8mm Lift Intake
Tomei Procam 270Degree 10.8mm Lift Exhaust
Tomei Adjustable Cam Wheel
Tomei Type B Valve Springs
Tomei Type B Titanium Retainers
Tomei Bronze Valve Guides
Twin Walbro 450 Fuel Pump with Frenchys Performance Garage Twin Pump In-Tank Fuel System Kit
Earl’s Pro-Lite Ultra Hose -8 AN Feed & -6 AN Return Fuel Line
Plazmaman Fuel Rail
Fuelab Fuel Pressure Regulator
ASNU 1400cc 14 Holes Injectors
Ross Performance Crank Cam Trigger Kit
Haltech Platinum Pro Plug-in ECU
Greddy/Trust Intercooler
Greddy/Trust Radiator
ATS Twin Plate Carbon Clutch
Tomei EXPREME Ti Exhaust
Edited by etang789
Don't get Tomei valve springs, they're made out of a child's faeces, get BC or Supertech.
Don't get Procams, where's @Piggaz? Lol
Don't get a Ross trigger kit, get the Platinum Racing one.
Don't get the Platinum Pro, go Elite 2000 or 2500 (more features and inputs/outputs)
  • Like 1
I was thinking Ferrea valve springs and valves before.
Which cams would you suggest then?
I prefer the Ross over Platinum Racing because the sensor mount looks more stock and the wiring isn’t just sticking towards front of the car
I already have the Haltech Platinum Pro Plug-In for running a few years already.
1 hour ago, r32-25t said:
Cause it does everything better
not wrong but a 2.6 is still going to rip lol
23 minutes ago, Dale FZ1 said:
Indeed.  When 3.4 is a tried and tested option.
dont forget to add a billet block to the list
Yeah go with those springs OR BC or Supertech, the Tomei rubbish will give you nothing but issues when you start feeding in boost.
CAMS, give Kelford a call/e-mail and tell them what you're doing - I have no faith in those brappy Tomei cams, many have ended up putting in stock cams and/or switched to much lower duration cams so power band is much more usable.
Looks don't mean much, however the PRP kits use cherry sensors and can be fitted to any crank damper/pulley unlike the Ross kits.
Also if you decide to get the PRP you can't use the Haltech Platinum Pro as you can't unlock the trigger settings haha..
Lastly,  why Tomei pump when a Nitto pump can be had? Since you're going Nitto most things, might as well get a Nitto pump.
I noticed the word "Tomei" often repeated in that list as well as GReddy/TRUST way too many times ???
7 minutes ago, Leroy Peterson said:
Need Tomei for dat Speedhunters feature
http://www.speedhunters.com/2018/04/project-gt-r-gets-bigger-turbos/
LOL EVEN BIGGER twins, for that crisp lag
Refer back to :
http://www.speedhunters.com/2013/05/project-gtr-and-the-road-to-new-lungs/
  • Like 3
7 minutes ago, Dose Pipe Sutututu said:
"Since this first step is all about low-end torque and throttle response, I thought the HKS route would be the best option."
Riiiiiightttt :D
Yes it will but if you ever get to drive a 2.8 you’ll agree that it’s money well spent
if mine lets go the first thing on the shopping list will be a stroker kit
  • Like 1
Riiiiiightttt :D
He probably got discounted shit, just an advertising platform.
You can't go that fast in car parks anyway.
  • Haha 1
Budget Supercar went 9.92 with a stock bottom end. 2.8 or not, thats moving.
I never said it can’t be done but it doesn’t make it the best way to do it or make it a better street car
there’s a reason maatouks, crd and etc up the capacity, cause it’s better
no replacement for displacement :)
(inserts disclaimer about variable CR, cam timing, lift, TS, DI)
Yea I have emailed Kelford already waiting for their reply.
I guess I have to stick with Ross kit unless I switch ECU then
Yea been thinking either Tomei or Nitto for oil pump. Seems more people have used Tomei that’s all.
Reason for Tomei Exhaust is seems like they are the biggest size exhaust that’s off the shelf avaliable and decently priced. Local exhaust shop here is crap so custom make one isn’t an option, can’t accept those Workmanship on my car.
Reason for quite some Greddy/Trust parts is because I bought the car with everything Greddy/Trust installed and unless it’s critical I guess I will keep them.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
