38 minutes ago, Dose Pipe Sutututu said:
Extra 2kW up top and -2kW mid range!
Time for me to flash the missus' Tiguan to get it from 162kW to 223kW lol.
Yes, but yesterday I was teaching the boy to do hektic dowies in a local cul de sac.
BTW, what is happening with your beastie?
You win, can't do donuts in the Nazi troop carrier lol.
Umm it's not in the backyard or my mate's shop any more haha... the siet bok is just getting a bunch of fab work done (that costs more than the car itself, I'm such a bad Asian, fk all ROI)
Umm it's not in the backyard or my mate's shoo any more haha... the siet bok is just getting a bunch of fab work done (that costs more than the car itself, I'm such a bad Asian, fk all ROI)
I'm such a bogan, I just had to Google ROI.
  • Haha 2
Cold start is now as loud as balls.
Cold start is for heating the cats up faster and can be tuned out, hopefully soon.
Went for a hour drive to cook off the heat wrap.
I might need a resonator in the front pipe, maybe, maybe not.
Stone guard thingie will go back on after I have heat cycled it a few times and re-torqued it all up.
Sounds hektik, LOL
27 minutes ago, r32-25t said:
Does it sound like a rexy bro?
Like a noisy one mate, like a noisy one.
Honestly, I really like it, it's just verging on being a bit too loud. Maybe get some unwanted attention type of loud.
I'm going to head into the local exhaust shop and see what they can do, a big arse resonator, louvered not perforated, in the front pipe might knock the tone/noise down enough to make me happy.
A 12" louvered hotdog knocked a heap of noise out of my MX5, I'm hoping it does the same for the 86.
  • Like 1
Now with added quietness, with the added benifit of the legalities....
Cold start is still louder then I really like, but, meh.
Normal running it is as loud as my old MX5, but deeper, and not tinny, plus no drone.
Chopped a turbo Nissan coming back, shallow victory though, it was a SSS.
  • Like 1
3 hours ago, Dose Pipe Sutututu said:
Line you up in the missus' fully taboulli Tiggy
SAU should do another drag day at WSID.
I went to one years ago with my boat (R33 GTST) and chopped everything, excellent day it was.
I would do another in the 86 for the LOLS alone, chopping some other daily drivers would be a bonus.
I'll buy the donuts.
I'll bring both cars, R33 will blow a gearbox then the Tiggy probably blow the haldex, DSG, motor, entire Canbus network will die and the car will light up 1500 error codes (thank fk it's under warranty)
  • Haha 2
Cold start was still to loud
So, now, my current exhaust is a Tomei UEL header, Ultrex 2.5" overpipe, OEM front pipe back.
Going to the smaller pipe isn't a worry as calculations say that 2 1/4" will flow more than enough NA.
And the OEM front pipe will flow the power its making without much of a issue and will save the kittens and frogs for future generations, which is a bonus.
In all honesty I wish I just did the header and overpipe to start with.
Or, stayed with the decat OEM header, 2 5" catless overpipe and 2.5" cat back, the only issue with that is the trail of dead kittens and frogs in my wake.
Like all things it was a lesson, albeit a slightly costly one.
Dooh.
  • 3 weeks later...
Had a play.
Punched out cat in front pipe.
Tomei UEL header showed no gains over the punched out OEM header.
Hell, the punched out OEM cats with the 2.25" OEM stuff showed typical performance to the Tomei UEL with 2.5" catless exhaust.
There is only so much NA powers you can wring from a 2.0 ltr boxer POS.
I will be reinstalling the punched out header and selling the Tomei.
Making more noise for no extra performance is pointless.
Yes I'm getting old...
I'm keeping this little puppy though, but, I have a itch that needs to be scatched.
Some cheap old POS might end up in the yard, the plant yard to be specific....at work.......hidden......from "her"
  • Haha 2
Until you start spending more time at "work"
12 minutes ago, mlr said:
Had a play.
Buy something cheap, like an 80 series cruiser. And shove a Barra turbo in it.
From memory get Barra after June 2006, and it'll happily make 500kw.
So then wind the boost in, injectors, FMIC, and go rip skids.
Even better run the ZF6 gearbox and turn the cruiser RWD just for the drag racing Lols.
I reckon you can easily get a 80 series into the low 12s in that combo.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
