2 hours ago, Dose Pipe Sutututu said:
You mean you run E85 full time.
PowerFC can't even cut power when you're above a particular load point, it can't even cut power when you've exceeded a particular engine water temperature.
I think you need to admit now that it is a pretty basic ECU.
Nistune can do full flex blending (PowerFC cannot), Nistune has basic engine protection (PowerFC will grenade your motor), Nistune you can vary your VCT (PowerFC you cannot), Nistune has launch control (PowerFC does not have), Nistune you can fully map the DC for the boost solenoid (PowerFC you cannot).
So tell why the PowerFC is better? Because of its useless hand controller?
Relax man.. was only a suggestion, it does sound good now from what you've said.. For a budget slapper with a $200 bottom end it works fine for me, obviously a haltech would be best..
I said i run flex as in eflex from united.
Did the nistune save your boat?
Edited by AngryRB
  • Haha 1
https://www.sau.com.au/forums/topic/474557-r34-nat/page/2/#findComment-7881724
Don't be obtuse.  It's not the definition of "flex" when referring to what fuel a car can run on.  That is a fuel company somewhat deliberately confusing matters.  It's also a far smaller slice of the ethanol market than is represented by United, which conveniently calls the fuel by a name that represents what it actually is.
  • Like 2
https://www.sau.com.au/forums/topic/474557-r34-nat/page/2/#findComment-7881791
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
