hey guys, im a new member to this forum
ive owned my r34 skyline (non turbo) for about 4 years now and since im off my p plates i want to turbo it now.
i cant be bothered selling it and then going through the hassle of looking for r34 gtt id much rather build up what i got now.
so i was wondering does anyone know any mechanics or someone who sells and/or installs turbo kits for skylines.
preferably somewhere located in the western suburbs of Melbourne.
any help/advice would be much appreciated
thanks, ?
The standard advice around here is to not do it. More pain and expense than it is worth.
There is no such thing as a "kit". You can try to scrape together the minimum things you will need to make it happen, which is;
  • Turbo + manifold,
  • exhaust,
  • intercooler,
  • injectors
  • fuel pump.
Oh, and an ECU, because the pain inherent in trying to make a GTT ECU run on a hacked together mishmash of things with some missing/wrong sensors etc etc is not worth it. Aftermarket ECU simplifies life.
But that ignores that you will destroy the clutch and so will need one of them. And the gearbox won't last too long either, so you really should put a big one in. And the open diff will have its own float in the Mardis Gras, and the front brakes will need upgrading.....and you're in Melbourne, so adding a turbo is like totally illegal without full engineering, so add that if you want your insurance to work.
What he said^^^
Selling your n/a and buying a GTT is a walk in the park compared to converting your current car. Its time to say goodbye...pass your car on to a P plater and get yourself a turbo model.
thanks for your advice.
in my original post i preferred to turbo what i got now, dont have much interest in selling then buying a gtt model. so im willing to go through the hassle of what it will take to convert it to a turbo.
ive heard its easier to just install the stock factory turbo that comes off the gtt model.
in regards to what i need like turbo, manifold, exhaust and those sorts of things my best bet is to find them online/ebay?
my r34 is the GTV model so i believe its got the diff and brakes necessary for a turbo conversion.
i know someone who can possibly engineer it properly should there be any problems with it being illegal to do.
On 07/06/2019 at 6:36 PM, Ben C34 said:
To turbo a car that is available turbo is silly.
LS swap it, then turbo that.
id think about putting a LS if i were to track it but because it would be for street use i want to keep it RB
On 07/06/2019 at 7:30 PM, Dose Pipe Sutututu said:
LS so 2010, Barra swap it. 500kW stock motor with just head studs, valve springs and a billet oil pump gear.
A RB can only dream.
i prefer to keep it RB
  • Like 1
so i have been thinking.
would it be best to save a bit of extra cash and sell what i have but instead of buying a GTT id just buy something else.
i would love to get a r32 gtr or evo 8/9
anyone know of any good import companies i hear iron chef imports are good.
anyone got any other suggestions on which import company they trust that are good?
It can be done!
You wanna do it. Learn . Accomplish.
https://www.sau.com.au/forums/topic/466795-doing-a-t-conversion-on-an-unopened-rb25de-neo-r34-gt/
Research is the begining.
Best kit is a loom ,ecu ,drive train and pump swap from a gtt.
11 minutes ago, Slap said:
It can be done!
thanks!
  • Like 1
https://www.sau.com.au/forums/applications/tapatalk/index.php?/topic/426222-If-You're-Happy-With-Your-Import-Car,-Who-Brought-It-In?
If You're Happy With Your Import Car, Who Brought It In?
These 2 are incompatible. The only people who should consider buying R32 GTRs at this point in history are those who simply do not need to "save a bit of extra cash". You have to budget on spending the purchase price of the car every 2 - 3 years just to keep the bloody things running.
Follow your heart , sacrifice the essential.
If you can pimp it... pimp it.
If you can sell and buy closer to your heart do it.
If ya want all of em collect and save.
If ya want fast get or make somthin fast.
I can only tell you what i did not tell you what or where you wanna buy.
I saved some money up
My r32 skidline was brought second hand in 2011 from Port Macquarie nsw off a fella called brad. He had old scool mods wich i learned to hack and make use of at the same time keeping it unique. Even had neons in the engine. I had to fix all the weak links in the chain of mods nothing drastic. He did a great budget job for back in the day. Cost me 3k had Porsche gt green with black graphic center stripe , looked cool but road worthy inspections were refused at multiple places untill it was painted.
So i learned to paint.
Wouldnt let it go ever now passing it down to a son (lucky bugger).
So good luck im sure you will find one but they are usualy 10-15k gtst and gts4 or 30k+ gtr
301880739_images20(4).jpeg.1a848f930f13ba7e640f874da70483db.jpeg20171210_175405.thumb.jpeg.63719fb43c33a63370528191ded86295.jpeg
"I can only tell you what i did not tell you what or where you wanna buy."
Not being interested in an engine/halfcut swap makes as much sense as the quoted sentence from the above post.
  • Haha 1
How does that make no sense.
Oh wait your post makes no sense.
My views of not buying a turbo car, and then putting a turbo on a non-turbo'd car, but also not using a half cut, from the same model of car of your non-turbo'd car, that came with a turbo, is like "I can only tell you what i did not tell you what or where you wanna buy."
That should clear things up nicely.......
  • Like 2
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
