HKS 2.8 (86.5mm), Tomei Pon Cams
Precision GEN2 6266 Twinscroll, 1.5bar/22psi
98RON Shell VPower, 660cc injectors, HKS in tank pump
611hp/455kw at the rear hubs at 6600rpm , 510lbft at 5200rpm
Before we built the 2.8 this turbo made 577hp at 1.2bar/18psi on a 2.6 with 87.5mm pistons (basically 2.7) with similar response.
  • Like 3
  • 3 weeks later...
1991 GTR
- stock RB26DETT (shows signs of a refresh but can't confirm)
- gt2860-5 twin turbos
- stock injectors
- HKS green mushroom intake
- 3in exhaust line
- HKS down pipe
Safe tuned at 356rwhp at 15psi.
(i will eventually upload the dyno curve once I get it by email)
  • 4 weeks later...
On 2/2/2017 at 11:10 AM, Darmanin10 said:
R32 GTR
gtx3576r with 0.83 rear housing
Tomei poncams & cam gears
1000cc xspurts injectors
3.5 inch exhaust
344kw @ 22psi
Same setup, but now forged engine setup for track abuse.
Needs bigger injectors for more power, as they are maxed out at this level.
1102422031_20180913_PaulDarmaninNissanGTRR32kWVsbOOst.thumb.JPG.29497fe2725a22d23aa8ee61468f9ff4.JPG
The RED line is cam timing before
BLUE  line is cam timing after
ORANGE line is high boost.
  • Like 1
1991 R32 GTR
Stock motor, headstuds
Rebuild JDS Performance R32 Turbos, N1 exhaust wheel, billet compressor wheel
Midori 3" outlets
2.75" to 3.5" twin pipe
3.5" exhaust
Modded twin turbo pipe
HKS hard piping kit
Blitz front mount, size big
Radium fuel rail, 1050x injectors, walbro 450
Full AEM sensors w/Infinity
Custom intakes since MAFs aren't required anymore
505AWHP 398TQ @21 PSI, 5280 elevation
Really happy with the power for the small turbos!
  • 1 month later...
  • 4 weeks later...
1992 R32 GTR
HKS GT-LC low mount twins (Unknown specs. Would love more info on these but can't find it!!!)
Haltech PNP on stock MAP sensor
Stock Intake
Stock Dump Pipes, Blitz Front Pipe, 3" Test Pipe, Fujitsubo 3" Catback
DYNO GRAPH
(Red Line: 408HP, 356 lbft; 16-18psi, 91 octane) [Blue line is Jap tuned ECU on 101 octane]
Next Steps (advice welcomed):
Greddy MAFless pod filter and pipe intake kit
HKS Cam Gears
Tomei turbo outlet pipes
ID1050x injectors
External MAP sensor
Walboro 450 fuel pump and rewire
Greddy 12 row Oil cooler and Filter Relo
HKS SSQV BOV kit
Twin Plate Clutch (Nismo Super coppermix or alternative)
ARP head studs
Metal head gasket
Possibly E85
Shooting for 550hp before i run out of puff from the snails.
Edited by UMZenki
N1 RB26
Poncams
-7s
Haltech elite 2500
427hp on 98
507hp on e85, somewhere around the 21 psi mark. Boost solenoid was on max duty.
Will be back with a high mounted GTX35.
Edited by sleptema
  • Like 1
  • 1 month later...
On 12/20/2018 at 7:17 PM, sleptema said:
N1 RB26
Poncams
-7s
Haltech elite 2500
427hp on 98
What version of Poncam's are on this? -7's seem to be on quite late. 20 psi at 5000rpm?
  • 2 months later...
Engine - Stock Rb26 Bottom end
Head - Tomeii type b poncams & tomeii adjustable cam gears. Brian Crower springs, supertec valves and guides
Turbo's - Twin factory mounted TD05-18g's, billet wheels with billet actuators
Brain - Nistune, turbosmart eboost street
Exhaust - Stock ex manifolds and dumps, Nismo front pipes then high-flow cat to 3.5 inch exhaust straight through to cannon
Fuel and supply - 98 PULP, 1170 xspurt injectors, nismo fpr, 450lt/hr pump
Intake/Cold side - Nismo AFM's, stock everything else stock including airbox, intercooler, blow off valves, piping and inlet mani
352kw's at the tyres on 19psi. Quite laggy but not as bad as expected, full boost hits just under 5k, 5 degrees adv on inlet cam, 2 on exhaust picked up heaps of mid-range. Very happy with the result, Mark from MRC worked his magic again, I was very nervous about those turbos, the stock airbox and exhaust manis/dumps but all and all it's great! I'll post a graph up shortly.
  • Like 1
On an intertia dyno I could see this being the case. -7 are significantly later on threshold and lag compared directly to 8374 efr single FYI all
Very similar, they are Mamba turbos. So non bb cartridges wich would be the only real downside other than the size for the 2.6. Be interesting to see them on a 3.0+
Are these t517z turbos?
  • 3 weeks later...
R33 GTR
Clicked 100,000kms on a budget built 2.6 on an old Power FC with 255rwkw so decided it's finally run in and went single turbo. [emoji23]
-proboost gtx35
-ETM manifold
-50mm turbosmart wastegate (18psi spring)
-1000cc Bosch injectors
-walbro 460
-standard cams
-adaptronic ecu
E85 of course
Manual boost tee maxed out, one slight turn and it just overboosts,
Needs a proper boost controller.
376.4kw on 23psi
Tuned by Jez
13 hours ago, JDM33R said:
R33 GTR
Clicked 100,000kms on a budget built 2.6 on an old Power FC with 255rwkw so decided it's finally run in and went single turbo. emoji23.png
-proboost gtx35
-ETM manifold
-walbro 460
-standard cams
-adaptronic ecu
E85 of course
376.4kw on 23psi
Tuned by Jez
Any chance you ran a 98 tune also?
  • 1 month later...
Forged RB26 (Sleeved block, 87mm Pistons, rods, rod bolts, head studs, N1 oil pump with billet gears, Tomei sump baffle, Tomei metal head gasket etc...)
-7 turbos rebuilt with larger billet wheels
Nistune ECU (Latest update - Flex Fuel, Boost control etc)
Standard Exhaust manifolds and intake piping (Port-matched to suit bigger wheeled turbos)
1250cc Injectors
460LP/h fuel pump
Nismo AFM's
Standard Air-box with CAI and K&N panel filter
Splitfire Coil packs
Kelford L182a cams
Greddy cam gears
Plazmaman 76mm intercooler
391rwkws @ 24psi (how it's driven) E85
417rwkws @ 26psi (airbox just cracked open) E85
335rwkws @ 20psi (how it's driven) 98RON
RB 28 with GTX3584RS used as Track car
HKS step 2 2.8 full counter rank rods and pistons
HKS 272 exhaust cam
HKS VCAM Pro with 10.2 lift
Ported head - ferrera valves etc
Peterson dry sump running vacuum
N1 block
Nismo Plenum
Modified ITB's
6 Boost stainless steel Promod manifold (Small runner)
GTX3584RS
1.21 rear housing
E85
Runing through Sachs carbon carbon clutch and flywheel (3kg)- Albins straight cut transmission and Nismo diff
stopped at 26 PSI 562 RWKW  was 420 KW at 13psi   705 ftlb torque.
Have posted so anyone thinking of using this turbo can see the results.
Probably a better choice would be the precision PT6870 or 6875  with a large runner manifold
Edited by Paul T
1
  • Like 10
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
