Please stay on topic or I will be forced to whack you with the ban stick, newbie :spank:
Freakin' Nazi's on this forum ...
:glare:
Ohh the admins are fighting........ *hides in corner* :unsure:
  • Like 1
Oh I see whats going on here! I'm being picked on and discriminated against!
This is cause I have VW's now, isn't it?
I work on vw's, whats yer point?
Don't worry, Christian - SAU-NSW Exec meeting tonight: Eric's R33 GT-R hidden away in the garage, Ciaron's R33 GTSt parked on the street, Mat and Carmen's LandCruiser parked on the street, Tats' Mk.VI Golf in Eric's driveway, my parent's new Mk.VII Golf also parked on the street.
If Mat and Carmen had used one of their other cars, it could have been three Skylines (Mat's R34 GTt) or three Golfs (Carmen's Mk. VI GTI). If I'd used my own car, it would be one LOLvo instead of Zee Cherman.
That's still kind of a Skylines spotted, right? (Hides from Duncan.) :ninja:
Saw a nice clean and low red R32 GTR passing me through North Bridge today, around 2pm.
Gave a thumbs up and I think I got one back, couldn't really see because he was moving quickly.
Also spotted a mini cruise last Saturday going through St Ives, yellow R33 GTST, white Stagea and white Evo 4 (i think). All very nice cars!
We parted ways at the base of Mona Vale road.
That's my old car!!!! how's it look?
I was going to say the plates were familiar lol.
Spotted a Burnt out R33 on Pennant Hills road couple days ago on back of a towey going up to Hornsby or on to the F3 motorway. Anyone know what happened?
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
