Do you still have these in stock for an R33 Series 1? If so, will be purchasing off you shortly after i get back from Japan :)
yes, we have plenty of stock.
  • Replies 217
Hi
could you possibly provide details of terms of warrenty? ie do they have to be installed by qualified mechanic?/in the event of a coil pack failure is customer responsible for sending faulty coil pack back to you and await for replacement coil pack?/
thankyou.
Hi
thankyou.
Installation is pretty straight forward and you shouldnt need a mechanic.
In the event of failure just get back to me and we can arange something to suit your situation.
  • 4 weeks later...
S15 Yellow Jackets are now available for $340/set delivered.
Also available.....
Brand New Yellow Jackets T-Shirts for $25.00 delivered
Front print - Plain back.
100% pre-shrunk cotton.
Available in white only.
Sizes - Small / Medium / Large / Extra Large / Extra Extra Large
Just ordered a set of R33 Series 2 coils through your website (Paypal).
Looking forward to ironing out that hiccup when on boost and maybe opening up the plug gap as well
Z
Z
Thanks very much. I just got back from the P.O so you should have them tomorrow. :cheers:
Fast and efficient. The package was waiting for me when I turned up at work. If only my other suppliers could offer service like this.
Z
Z
No probs at all :cheers:
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
just confirmation on people undecided, ordered these on a monday they arrived in 1.5 days later (to perth!)
chucked them in, put back on dyno today, all misfire issues are gone and got 310hp on a safe tune with rb20 (not huge power but misfire is gone :D)
im well happy, and with the price and warranty cant beat these
just ordered today, should come in friday and monday, now the only feeling left in me is the worry about not being able to reassemble the engine hoses and stuff! =[
Excellent. Im glad you are happy with your purchase. :cheers:
You should be fine. Take your time and make a note of how you got them off and then follow the same steps when reassembling. :)
  • 4 weeks later...
Now in stock....
Yellow Jackets for CA18 (No adaptor harnesses required) - Only $300/set.
And also early model RB20 engins (No adaptor harnesses requried)- - only $370/set.
See here for info or to purchase.
:cheers:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
