Indeed you cannot, hence why I am skeptical about getting traction with them on the 1/4.
Well i don't have much issue on the street with my car unless i just dump the clutch :P
For a normal "launch" where i'd feed off the clutch it'll be off... only issue is the bordeline between traction & not - this is where axel tramp now kicks in as the RE001's are a bit more gripp than 3000A's
Dammit Ash I've been waiting to see your car for a long time. What happened to those rumours you heard?
It's close - but not end of next week close... probably 3 weeks :D
  • Replies 234
do both?
ive done quite a bit to the datto to prep it for winton, and its my first proper track day with it
ive been hanging to get out there so i dont really wanna risk breaking it the day before, id rather break it there :thumbsup:
so ill have to join you guys next time
Anyone gonna meet up and cruise to heathcote?
Will probably have the car on a trailer, but don't mind cruising alongside others :)
never been to heathcote so will probably tag along if anyone is organising a cruise for saturday morning.
I might have to bail :verymad: I havent made the changes to the car I wanted to so no point running it with the same setup...
But we'll see what I can pull off over the next week.
Then give me your slicks!!!
i think this is the last outing for my silvia, so i'm not spending anymore money on suspension setup's, or correcting the toe in wheel alignment for strip use.
bring on the wheel spin ! i should get traction about 75mtrs down the track, oh no wait ive got a plan !
i'll inflate the tyre's on every wrx i see to even out traction loss, 50psi should do it :)
Ash I've been in the club for 7 years and only ever seen your car once or twice and never entered in anything except maybe a show and shine.
You've spent a heap of coin on it....
You need to give it a hard time!
Abuse it!
It doesn't have any doors/windows... bit of a problem for a Drag Day! (it's down @ Micolour)
And the fact it is up For Sale once its complete is telling me to be very careful with what i do :P
I know the feeling, bubble wrap FTW ;)
EDIT: Do we have a definitive list of members attending?
my rebuilt brake master cylinder decided to spill all its contents :)
New brake master cylinder being installed next week and hopefully I'll get the thermo-fan controller wired in!!
Always a rush to get the car ready for events haha
Word.
To do before Saturday: swap turbo, retune, roll guards, wheel alignment, strip unnecessary weight :\
haha good luck to you sir! but i guess you on holidays now? so should be reasonable to get it done in time!
i may not make it in time for this :)
gearbox builder says nissan has ceased production of early model R32 gts4 parts.
Anyone have a R33 GTR gearbox for sale? PM me if you do.....
unfortunately in 100% out. Just confirmed won't be ready this week :)
this sux, i was looking forward to this for the last few months... :)
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
