Fitted a 350Z midpipe to mine today. Got a muffler guy to weld 6 inches onto the end to make it PM35 length. in retrospect 7 inches is the go, 6 inches works but is too short. Hangers are identical. A V35 coupe will bolt straight in I believe, I got the Z because it was ....cheap :)
This is the difference- 1 big muffler in the std one, and a resonator in the 350Z. Sounds great on the car, brings the tone to life without being too loud/droney
Oh, and about 7 kgs difference in weight! Oh and the diameter is bigger too... win!
Edited by PN-Mad
Changed second steering pump today...bit of a bitch of a job.....keeps shitting the inner's...thinking I might have to put a bigger wheel on it if I'm going to track this thing!
oh & alll the BS is good in this THREAD OH NO ONE POSTS IN HERE JUST SOME STAGEA OWNER :wacko: ,
YOU MUST BE SPECIAL DALE :spank:
I DID SOMETHING TO MY CAR :stupid:
:google:
I Made a clip to hold a cable to body :worship:
:yes: oh & a new battery :bunny:
i may change oil soon may have to think about this & ask some thats Special :wacko:
can we Sticky :yes: this thread so many helpful pinch.gif hints
easy fix bud.....go start you own "CHUCKIES BUILD THREAD!" thread....then you wont have to come in here and be part of the community....oh and can I ask....Did you start this thread? Pretty sure the original thread was started by Dale...and M35 ownerohmy.gifpwned.gif
Oh and I'm pretty sure this wasn't so much of an info thread but just general conversation on what you have done to your car today......even if you did fart in it and mix the smell with WB40(good one Andrew...lol!...I mixed mine with auto fluid). So if you want serious info go do a frigging search buddy!
And a big pointer for yah!...cap's for yah too!
IF YOU DON"T LIKE THE THREAD DON"T COME IN HERE!
Edited by Jetwreck
The C34 got some love today....
Oil and filter
02 Sensor
Check and adjust of all other fluids
Bay wipe down
Also had a crack at getting my windscreen jets to start spraying a good flow of water again to no avail.... Pulled them off and stuck a pin through the holes on the top and where the hose connects to with slight improvement but not much..... Ideas? Is their a diaphragm inside these of some sort to help build up pressure or anything that I may have stabbed through with the pin?
Thanks for all your HELP ,
I guess owning a NM#% is some sort of gift ,
i guess with all your imput i will be happy to have a NM#% in the family & may be you will be more helpfully then,
but as its my DAD`S He can enjoy knowing a mob of EBW :cheers:
  • Like 1
  • Nope 10
FITTED 2 NEW BOLTS TO MY Brakes :thumbsup:
:rolleyes: is this a MOD i CAN POST :wacko:
or do i need aprovall from NM#%
But i may need to ask if it`s ok to POST :spam:
hope to POST MORE SOON :thanks::cheers:
  • Like 1
  • Nope 11
Got power steering pump back today...got new centre put in with more vein's and a larger wheel on the pully!
Hopefully it all works....especially on idle!
Deadset nummer's....you have to keep poking at the hornet's nest don't yah!....most of us(c34 and M35) just want to get along(E.G. C34 and M35 cruise together or have meets in NSW, Vic and SA)....love how you blame the M35 owners but the thing is buddy we were getting along with the C34 guy's till you and your mate Jason + 1 or 2 others came and started flaming us....I even did a reach out to you but even that wasn't good enough.......had to go and make something false out of it didn't yah!
Well I've met some simpleton's before butt I have to say....if trying to destroy the whole SAU Stagea section is your goal hat's off to you budworship.gif
Edited by Jetwreck
  • Like 4
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
