Great job mate. Easy isn't it!Best kept secret, can't believe nobody gave it a ago before me.
Slippy, it is the 350z that needs a bit of extension.
Put the extended 350Z mid-pipe in (has been passed around a few cars on this forum I think...) yesterday. As mentioned, bit more note, bit more performance. The thing I noticed was smoother throughout the rev range. I had a bit of a flat spot that's gone now.
Dead-easy fit, bolt straight in!
EXCEPT... Nuts on the front flange were rusted solid... Rounded off nicely with the right sized ring spanner... Angle-grinder to get them off, then the studs wouldn't come out so had to drill them out. 20 minute job took all afternoon! Still, happy with the results - CHEAP and easy upgrade. Keeps the minister for domestic affairs happy too!
That my old one is it? Good to see its back in NSW!
My air con hasn't been working, which is somewhat understandable with some of the high temps we've seen lately in Adelaide.
I figured it might have something to do with the thermo fan, which hasn't worked since I put it in. I have never seen it spin.
Hooked the multimeter up, and only measured a negligible voltage. I cut off the dodgy solder connection, and put new crimp connectors on. Tested with a 9V battery, and the fan span up and ran fine.
So the problem must be the signal to the fan - the car just isn't switching it on. Is there a fuse I should be looking for, or is the car just deciding it doesn't need to kick this fan in?
I seem to remember this fan also sitting in front of the air con condenser, so thought this could be responsible for the crap air con.
Any ideas?
got stuck in stop/start traffic on the way home, and got bored so started playing with my fc commander. Good thing, because I noticed the coolant temp was higher than it should be (102deg) , and creeping higher.
So I managed to get it to my mech's workshop (was on my way there anyway), and discovered that I had melted the fuse for my thermo fan. Lucky Lucky Lucky I caught it in time: coolant reached a max of 115deg before shutdown....
I'm now looking at other options: breaker instead of fuse on thermo, or like I orinally wanted: twin thermos on independent circuits: I'm all about redundancy... Opinions?
Finally fitted my full exhaust on my M35 replacing the old, tired Kakimoto R cat-back
Fitted the AM Performance dump and mid-pipe along with a brand new SS Kakimoto R cat-back
Impressions..
Much deeper sound, revs so much more freely and quicker up the ranges.
Spools alot louder and harder. Just sounds so much better
Very impressed over all. Spent over $2K all up and had to wait 2 months but I'm happy..
Highly recommend all items.
Stock fan!
Glad you're very happy with the results, but I am confused.
Kakimoto R (and N1 for that matter) only came in stainless steel. DO you have a pic of the cat-back that was removed by any chance?
Maybe it was just a really "old and tired" kaki replaced by a shiny new one...LOL
wish I had the $$$ to replace my not so old but dented Legalis with a new one!
No picture but definitely mild steel. Had rust spots everywhere. I didn't know mild was an option but I guess it was back then. It a very old looking unit, the old one had a mid muffler as opposed to a resonator on the new unit.
BTW Ian, got the BOSE sub running.. not bad for a tiny sub. Does the job perfectly!
Is this the factory Bose spare wheel sub into a non Bose factory head unit? Please PM connection details if it is.
Cheers
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
