Great job mate. Easy isn't it!Best kept secret, can't believe nobody gave it a ago before me.
Slippy, it is the 350z that needs a bit of extension.
Put the extended 350Z mid-pipe in (has been passed around a few cars on this forum I think...) yesterday. As mentioned, bit more note, bit more performance. The thing I noticed was smoother throughout the rev range. I had a bit of a flat spot that's gone now.
Dead-easy fit, bolt straight in!
EXCEPT... Nuts on the front flange were rusted solid... Rounded off nicely with the right sized ring spanner... Angle-grinder to get them off, then the studs wouldn't come out so had to drill them out. 20 minute job took all afternoon! Still, happy with the results - CHEAP and easy upgrade. Keeps the minister for domestic affairs happy too!
That my old one is it? Good to see its back in NSW!
My air con hasn't been working, which is somewhat understandable with some of the high temps we've seen lately in Adelaide.
I figured it might have something to do with the thermo fan, which hasn't worked since I put it in. I have never seen it spin.
Hooked the multimeter up, and only measured a negligible voltage. I cut off the dodgy solder connection, and put new crimp connectors on. Tested with a 9V battery, and the fan span up and ran fine.
So the problem must be the signal to the fan - the car just isn't switching it on. Is there a fuse I should be looking for, or is the car just deciding it doesn't need to kick this fan in?
I seem to remember this fan also sitting in front of the air con condenser, so thought this could be responsible for the crap air con.
Any ideas?
got stuck in stop/start traffic on the way home, and got bored so started playing with my fc commander. Good thing, because I noticed the coolant temp was higher than it should be (102deg) , and creeping higher.
So I managed to get it to my mech's workshop (was on my way there anyway), and discovered that I had melted the fuse for my thermo fan. Lucky Lucky Lucky I caught it in time: coolant reached a max of 115deg before shutdown....
I'm now looking at other options: breaker instead of fuse on thermo, or like I orinally wanted: twin thermos on independent circuits: I'm all about redundancy... Opinions?
Finally fitted my full exhaust on my M35 replacing the old, tired Kakimoto R cat-back
Fitted the AM Performance dump and mid-pipe along with a brand new SS Kakimoto R cat-back
Impressions..
Much deeper sound, revs so much more freely and quicker up the ranges.
Spools alot louder and harder. Just sounds so much better
Very impressed over all. Spent over $2K all up and had to wait 2 months but I'm happy..
Highly recommend all items.
Stock fan!
Glad you're very happy with the results, but I am confused.
Kakimoto R (and N1 for that matter) only came in stainless steel. DO you have a pic of the cat-back that was removed by any chance?
Maybe it was just a really "old and tired" kaki replaced by a shiny new one...LOL
wish I had the $$$ to replace my not so old but dented Legalis with a new one!
No picture but definitely mild steel. Had rust spots everywhere. I didn't know mild was an option but I guess it was back then. It a very old looking unit, the old one had a mid muffler as opposed to a resonator on the new unit.
BTW Ian, got the BOSE sub running.. not bad for a tiny sub. Does the job perfectly!
Is this the factory Bose spare wheel sub into a non Bose factory head unit? Please PM connection details if it is.
Cheers
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
