Scotty - you mean Me?
back then I was working, and obviously wasnt worried as cash wasnt a problem....
Hindisght is great, but who knew my health would have gone downhill to the extent that it did.
What I shouldnt have done was sell the stock parts off.
Point of worrying now is Id have to strip it if I got defected, and sell it in parts. Not easy to do when youre not physically capable.
Or you could have left the stock parts there and avoided the defect situation all together. I have seen 430kw on the stock manifolds and 500kw through a stock panel filter with the lid modified. Stealth power is the goal... I just wish I could explain it to more owners before they spend big on race parts for the street.
Welcome to the nanny state syndrome. We have been putting up with it in Vic for years.
  • Like 1
I just did this wire mod, what do you guys think ?
http://www.youtube.com/watch?v=U1sGB5wzTQI&list=UUy8-_O-nFlyB3bc8f3ywJsg&feature=share
Edited by poohkies
  • Like 1
So since installing my coilovers I'm having the same problem as ghost. Wheel and tyre hit the coilover now on compression. The gap is a couple mm different on each side which is weird.
I've raised the back but it still does it on big bumps. will have to figure something out.
all fun and games when you want "fitment"
Quite. Your rims are clearly too wide. You will get the same look with narrower rims with different offset or spacers.
keep driving it, it will self clearance itself after a while...lol
cheers
darren
Did a quick touch up on the tune today, didn't lean on it as my laptop (with the program & tune files) was having connectivity issues with the AEM Fic-8 ecu. Laptop is ancient and kids have kicked it once too often in the car.
Low boost tune @14psi made 247kw. Plenty left in it, but putting up for sale so decided not to push it.
Would have been nice to max it all out, but nevermind.
haha yeah right darren,
18x10+15 with a 265 at -1.2deg camber had those on with the cusco's too till I put the jtc's in
That's weird, I've got 9.5 +12 with 245 45. no camber adjustment in the back. it looks like as the camber increases on compression it hits. So if add some more positive it might fix it.
get a big washer from bunnings and space out the bottom mount or get a longer bolt and use more washers.... if yours is an auto/auto converted to manual ( r33 rwd rear strut )
manual rear cradle so no can do.
troy that looks good, not too sure on the chrome strip though, might work
And thinking about also doing the chrome strip that goes around the car.
I've painted the grill matt black too but wouldn't get rid of the chrome strip as it will make the car look more dumpy if you know what I mean...
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
