Scotty - you mean Me?
back then I was working, and obviously wasnt worried as cash wasnt a problem....
Hindisght is great, but who knew my health would have gone downhill to the extent that it did.
What I shouldnt have done was sell the stock parts off.
Point of worrying now is Id have to strip it if I got defected, and sell it in parts. Not easy to do when youre not physically capable.
Or you could have left the stock parts there and avoided the defect situation all together. I have seen 430kw on the stock manifolds and 500kw through a stock panel filter with the lid modified. Stealth power is the goal... I just wish I could explain it to more owners before they spend big on race parts for the street.
Welcome to the nanny state syndrome. We have been putting up with it in Vic for years.
  • Like 1
I just did this wire mod, what do you guys think ?
http://www.youtube.com/watch?v=U1sGB5wzTQI&list=UUy8-_O-nFlyB3bc8f3ywJsg&feature=share
Edited by poohkies
  • Like 1
So since installing my coilovers I'm having the same problem as ghost. Wheel and tyre hit the coilover now on compression. The gap is a couple mm different on each side which is weird.
I've raised the back but it still does it on big bumps. will have to figure something out.
all fun and games when you want "fitment"
Quite. Your rims are clearly too wide. You will get the same look with narrower rims with different offset or spacers.
keep driving it, it will self clearance itself after a while...lol
cheers
darren
Did a quick touch up on the tune today, didn't lean on it as my laptop (with the program & tune files) was having connectivity issues with the AEM Fic-8 ecu. Laptop is ancient and kids have kicked it once too often in the car.
Low boost tune @14psi made 247kw. Plenty left in it, but putting up for sale so decided not to push it.
Would have been nice to max it all out, but nevermind.
haha yeah right darren,
18x10+15 with a 265 at -1.2deg camber had those on with the cusco's too till I put the jtc's in
That's weird, I've got 9.5 +12 with 245 45. no camber adjustment in the back. it looks like as the camber increases on compression it hits. So if add some more positive it might fix it.
get a big washer from bunnings and space out the bottom mount or get a longer bolt and use more washers.... if yours is an auto/auto converted to manual ( r33 rwd rear strut )
manual rear cradle so no can do.
troy that looks good, not too sure on the chrome strip though, might work
And thinking about also doing the chrome strip that goes around the car.
I've painted the grill matt black too but wouldn't get rid of the chrome strip as it will make the car look more dumpy if you know what I mean...
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
