servicing the rs4s and gonna change all the transfercase/ diff fluids.
will be interesting to see if there is a noticable change in driving.
i have heard that people get allot more movement from the torque split guage once doing so.
any recomendations on which diff/ transfer fluids to use? (i assume there going to be the same anyway?)
No transfer is a good synthetic atf diffs depend on whether you have a mechanical LSD or the viscous one.
Clutch was slipping stressed as it's on 20k old, seems id adjusted it to much on the Slave and through ware it's got to its limit, re adjusted now it's chearpin again :). Also installed a knightrider light! Wanted it since I was 6, lost the remote couldn't turn it off, drove to the shops! Kids pointed and laughed! It would havd been cool in 86 :P
I've painted the grill matt black too but wouldn't get rid of the chrome strip as it will make the car look more dumpy if you know what I mean...
Ive just painted the corner strips, yet to do the doors. If i dont like them, could i strip the paint back with some turps or metho without damaging the factory paint?
wheres the pics?..lol
cheers
darren
I have 595rsrs on mine mate, they are awesome! I can mash the throttle around a corner and I just get a touch of power oversteer before they hookup on 235/35/18s. With over 300kw atw :)
Did you do the white lettering yourself?
Edited by stageaharts
repaired passenger side electric window switch, was a bit of fiddling with the internals of the switch but got it going again
also adjusted both front windows so they tuck into the slot to hold them in so water doesn't come in, was actually nice and a lot more quite inside the car :)
pads front and rear and put on some d1r's 17x8 +25. pretty much a perfect fit for a daily! need to lower the rear 20mm though. I never bothered re-blacking the bumper trim because i am going to spray them all in kr4. Do you guys reckon i could just rub back the sides and front or will the stuff wreck/seep through under the paint? It's been for roughly 4ish months.
Also Snatch the kitteh
Edited by Stagea97
I've run semis on my other cars but can't justify them yet on the stag ! Cornering is all good with my suspension setup and just the atr's on. traction off the line at the moment with the full race ets pro standalone unit taking over from altessa computer is a lot better, 6k launch slight w/spin and bam out of there:) 10s with 265 on the rear help too see how it goes with the next touch up tune should game a chunk more under the curve !
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
