On 12/14/2018 at 5:54 AM, NicPM35 said:
Does that mean the rear weight of the car is now on the 2 small bolts holding the original shock in place? Assuming the spring is no longer in it's perch
Correct. I've been running MCA Street Performance Series coilovers in my M35 since March and honestly cannot fault them. I've also had a full car load of passengers as well as a loaded boot and they held up perfectly fine. MCA are a company I wouldn't doubt in the least.
  • Like 1
  • 1 month later...
So after about 2 years at 297ATW KW I need more. dropped my 260RS of at Maatouks Racing last Thursday, motor should be out by Wednesday this week to get a full build done. Not sure what will be done yet until the block & crank are inspected but either way 650KW ATW should be happening in about 6-8 weeks. Going back down this week to pick up the car without the motor so I can tidy up a few things while it easy to get in & under the front end. The boys were impressed with how clean & straight the old Stagea is so I'm sure they'll look after it, as soon as I get more info & they start the work I'll post update & picks. Wish me luck...
  • Like 2
lol that should get you to the shops OK!
  • 2 months later...
9 weeks any news yet?
Still waiting they had a few things come up like responding to JUN2 beating their 1/4 mile time   I don’t want to rush them as it’s not easy to get work done on a Stagea by a GTR specialist  plus the wife has a M135i BMW (278KW) & I  have a Harley & a BMW sports tourer as well.
Yea it should get me to the speed limit very fast. ?. Still waiting they had a few things come up like responding to JUN2 beating their 1/4 mile time   I don’t want to rush them as it’s not easy to get work done on a Stagea by a GTR specialist  plus the wife has a M135i BMW (278KW) & I  have a Harley & a BMW sports tourer as well
  • Like 1
  • 3 weeks later...
Finally got around to installing my 4G wireless router. Bought this for ease of use with the Raspberry Pi rather than hot-spotting off my phone each time. It's mounted in the passenger-side cubby and power tapped off the stock Japanese tuner. It automatically turns off with accessories. The car switch for the Raspberry Pi has stopped working though... Contacted the vendor but might have to buy another one.
Also setup the OB Link. Works perfectly. Does everything I want except trans temp.
  • Like 1
  • 4 weeks later...
OK so its started Fully forged RB30 1000HP bottom is being machined & built & my RB26 head is also being machined & upgraded, soon for all the new parts to be ordered. The crank decided the direction I headed - see uploaded image & find the fault :) Anthony Maatouk has come up with just what I wanted a bullet proof forged motor...
Edited by TMLP
changed .HEIC to .jpg files
  • Like 1
Bought mine another battery, it was fine on Friday but dead today. It hardly moves since we got the Leaf, and the battery was churning out a massive 0.03V this morning when I checked it. Not ideal considering I'm off on a 600km business trip on Friday.
I think one of the bonnet hinges has collapsed as the bonnet is catching on the left-side quarter panel when I open it, takes quite an effort to get past the point of resistance but eventually it goes "BANG!" and everything moves freely again. :P The tip of the quarter panel is rusting now after all the rubbing but meh, it's just the beater these days. One day maybe I'll show it some love. Maybe.
OB link looks nice. What are you using the Pi + 4G for?
Update: SOMEONE (not giving anything away but you can bet she's going to cook me some eggs*) left the dome light on, hence the drained battery.
*NZ in-joke.
Not much really. Mainly streaming music. Quite often it'll be on the Monstercat radio stream via Twitch or stuff from my YouTube subscriptions which are automatically downloaded using youtube-dl. It also has RetroPie installed with a heap of ROMs and an 8BitDo SNES Bluetooth controller. 4G is just for convenience.
  • 2 months later...
Ok bottom end done full NITTO 3L grout filled & brace adapter for the sump & front diff. Waiting on the head ?
Exciting! What turbo do you have lined up?
That is badass, my dude. Very keen to see where this goes haha.
  • Thanks 1
Maatouks are picking everything based on the power & reliability I asked for so apparently a Precision but I don’t know what one yet. As soon as I get the specs & parts list I’ll post it.
Got rid of the HKS pods and went back to a standard airbox, but since I run a MAP sensor , no AFM. Haltech ECU instead of standard and FCON PRO, Had new Longer BC inserts put in the front suspension to raise the car off the ground. Just waiting for a MOMO Factory wheel to turn up. All fluids changed, new battery. New radio,new tyres. New cam belt and water pump and new secondhand heater box, and fix sundry leaks
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
