On 18/12/2019 at 10:40 PM, Cowboy1600 said:
What rails are you running with these?
I think they are S13/14 rails 3 out of 4 bolts lined up I just made a bracket to line up the last bolt
  • 2 months later...
Took out the crap Febest bits tension rod bushes that only lasted 50,000ks. Replaced with oem. Bit expensive but they'll last 150 probably. No more wanders!  And new sway bar links. Oem. No more clunking! Drives nice again.
  • 1 month later...
1 hour ago, Ottdurr said:
When replacing valve cover gaskets I decided to do a full clean and paint of both covers as well as the intake manifold, gonna throw away the plastic engine cover now it's actually a kinda nice looking engine 20200324_152506.thumb.jpg.1cf7234ef72a5062ec8957dc22fba16f.jpg20200329_123928.thumb.jpg.454c0e283455b9da435fbe4dcc09360f.jpg20200329_132216.thumb.jpg.246365a18e1ba3ba08466afb8ba691f5.jpg
Looking good!
  • 4 weeks later...
After a month of toing and froing between the engineer and the road worthy inspectors the ATTKD 6 piston brakes on our  '05 PM35 Axis Autech have been passed (the engineer was awesome, and so are the brakes).  More of a challenge was the rear track - 1565mm which was 5mm over what is allowed.  At the end of the day standard ARX wheels on the back did the trick but looking for something more suitable.
Why was the maximum track 1560? Did the wheels stick out of the guard or was it an arbitrary number?
Wheels are inside the guard - allowable track increase is 25mm and can use the widest track in that model of car - we used 1535 which is a PNM Axis and that gives me a limit of 1560mm.  My wheels are 18x9 with 25 offset - still getting my head around offset but thinking that 18x9 with 30 offset might bring the track in.
Yeah, +30 means it'll sit 5mm inwards compared to +25
  • Like 1
  • 4 weeks later...
so its about time i have written in the topic. my stagea journey started roughly 6 years or so ago when my mum was looking for a new car and had always liked nissans but wanted something practical and she decided on a m35 that she kept for a few years and i had always had a thing for wagons and i had decided a 260rs was what i needed in my life. late last year i put the plan into action and i was able to get a series 2 260rs.
first thing to sort out was the clutch i knew the clutch was on its way out when i bought the car but it didnt worry me all that much as i was planning to change it anyway for increased power. i went with a nismo twin plate and took a couple of days off work to get it sorted. luckily for me im a mechanic at a nissan and we werent all that busy so i was able to come in and use my hoist as i dont think i would have been able to do it on my own on stands.
the car sat on display in the showroom at my dealership for a period of time and while noone really knew what it was it was interesting seeing people wonder why it was in there with all the new cars and reading the plaque i had written that sat beside it
from there  the parts collecting began. i noticed while doing the clutch the front pipe flex joint had torn and was the source of an exhaust leak so that was on the list as i knew i was keeping the car on twins. i ended up getting -9's, hks cam gears and timing belt, genuine waterpump, tentioner, idler cam and crank seals, nismo fuel pump, 950cc injectors, nismo afms, prp r35 coil kit, nismo short and solid shifter with a power fc to run it all at this current stage.
while sadly i dont have any photos of the shifter install it went quite smoothly apart from from getting the selector cup to seat into the gearbox however perseverance and the occasional swear made it go in eventually
the coil kit install was a breeze i decided to change the plugs while i was there and lucky i did the plugs werent old or anything but were a 5 heat range and simply not up to the task of the power i was about to throw at the car. the old coil loom looked tired and was very brittle as expected. i retained the factory igniter box even though it isnt plugged in with the new coil kit as the car had a couple of ground connections running to it
so next is the car is booked in at racepace to have everything fitted and tuned so hopefully ill have a nice looking dyno sheet to post in a week or so
  • Like 1
Tiiiiiidy!!
pic 3 - am I trippin or is that a larger mouthed turbo inlet pipe with tape over ?
On 5/16/2020 at 12:52 AM, RBW49N said:
Have you done that 1000 km yet
Sure have, I found a heap of small fixes that needed to be done like vacuum leaks cam cover oil leaks & stuff but the big one was the 3" exhaust & JDM mufflers were not as well flowing as they needed to be, so after having issues with back pressure I had to get a full custom 3 1/2" system made up with 3 1/2 inch Hi Flow CAT, plus I had the screamer pipe extended & plumbed back into the exhaust so I don't get booked, after an oil change I took it back to Maatouks & had another run on the dyno to make sure all is OK. found out the standard CAS doesn't like anything over 6500rpm so I'm saving up for R35 coils & bracket & a cam angle sensor to go in when I go back for the E85 tune after all this COVID shite... so its still running on great 98 octane at just over 500whp so reliable everyday, very happy & the idle is much lower now & the car shakes a bit at the lights..;)
  • Like 1
  • 2 months later...
I'm still working on wiring my Haltech in. Making some progress but now the thing won't start so (on the stock ECU) I can't test my latest connections!
I did however just purchase a hypergear ATR43 ball bearing turbo... should be here next week ?
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
