On 18/12/2019 at 10:40 PM, Cowboy1600 said:
What rails are you running with these?
I think they are S13/14 rails 3 out of 4 bolts lined up I just made a bracket to line up the last bolt
  • 2 months later...
Took out the crap Febest bits tension rod bushes that only lasted 50,000ks. Replaced with oem. Bit expensive but they'll last 150 probably. No more wanders!  And new sway bar links. Oem. No more clunking! Drives nice again.
  • 1 month later...
1 hour ago, Ottdurr said:
When replacing valve cover gaskets I decided to do a full clean and paint of both covers as well as the intake manifold, gonna throw away the plastic engine cover now it's actually a kinda nice looking engine 20200324_152506.thumb.jpg.1cf7234ef72a5062ec8957dc22fba16f.jpg20200329_123928.thumb.jpg.454c0e283455b9da435fbe4dcc09360f.jpg20200329_132216.thumb.jpg.246365a18e1ba3ba08466afb8ba691f5.jpg
Looking good!
  • 4 weeks later...
After a month of toing and froing between the engineer and the road worthy inspectors the ATTKD 6 piston brakes on our  '05 PM35 Axis Autech have been passed (the engineer was awesome, and so are the brakes).  More of a challenge was the rear track - 1565mm which was 5mm over what is allowed.  At the end of the day standard ARX wheels on the back did the trick but looking for something more suitable.
Why was the maximum track 1560? Did the wheels stick out of the guard or was it an arbitrary number?
Wheels are inside the guard - allowable track increase is 25mm and can use the widest track in that model of car - we used 1535 which is a PNM Axis and that gives me a limit of 1560mm.  My wheels are 18x9 with 25 offset - still getting my head around offset but thinking that 18x9 with 30 offset might bring the track in.
Yeah, +30 means it'll sit 5mm inwards compared to +25
  • Like 1
  • 4 weeks later...
so its about time i have written in the topic. my stagea journey started roughly 6 years or so ago when my mum was looking for a new car and had always liked nissans but wanted something practical and she decided on a m35 that she kept for a few years and i had always had a thing for wagons and i had decided a 260rs was what i needed in my life. late last year i put the plan into action and i was able to get a series 2 260rs.
first thing to sort out was the clutch i knew the clutch was on its way out when i bought the car but it didnt worry me all that much as i was planning to change it anyway for increased power. i went with a nismo twin plate and took a couple of days off work to get it sorted. luckily for me im a mechanic at a nissan and we werent all that busy so i was able to come in and use my hoist as i dont think i would have been able to do it on my own on stands.
the car sat on display in the showroom at my dealership for a period of time and while noone really knew what it was it was interesting seeing people wonder why it was in there with all the new cars and reading the plaque i had written that sat beside it
from there  the parts collecting began. i noticed while doing the clutch the front pipe flex joint had torn and was the source of an exhaust leak so that was on the list as i knew i was keeping the car on twins. i ended up getting -9's, hks cam gears and timing belt, genuine waterpump, tentioner, idler cam and crank seals, nismo fuel pump, 950cc injectors, nismo afms, prp r35 coil kit, nismo short and solid shifter with a power fc to run it all at this current stage.
while sadly i dont have any photos of the shifter install it went quite smoothly apart from from getting the selector cup to seat into the gearbox however perseverance and the occasional swear made it go in eventually
the coil kit install was a breeze i decided to change the plugs while i was there and lucky i did the plugs werent old or anything but were a 5 heat range and simply not up to the task of the power i was about to throw at the car. the old coil loom looked tired and was very brittle as expected. i retained the factory igniter box even though it isnt plugged in with the new coil kit as the car had a couple of ground connections running to it
so next is the car is booked in at racepace to have everything fitted and tuned so hopefully ill have a nice looking dyno sheet to post in a week or so
  • Like 1
Tiiiiiidy!!
pic 3 - am I trippin or is that a larger mouthed turbo inlet pipe with tape over ?
On 5/16/2020 at 12:52 AM, RBW49N said:
Have you done that 1000 km yet
Sure have, I found a heap of small fixes that needed to be done like vacuum leaks cam cover oil leaks & stuff but the big one was the 3" exhaust & JDM mufflers were not as well flowing as they needed to be, so after having issues with back pressure I had to get a full custom 3 1/2" system made up with 3 1/2 inch Hi Flow CAT, plus I had the screamer pipe extended & plumbed back into the exhaust so I don't get booked, after an oil change I took it back to Maatouks & had another run on the dyno to make sure all is OK. found out the standard CAS doesn't like anything over 6500rpm so I'm saving up for R35 coils & bracket & a cam angle sensor to go in when I go back for the E85 tune after all this COVID shite... so its still running on great 98 octane at just over 500whp so reliable everyday, very happy & the idle is much lower now & the car shakes a bit at the lights..;)
  • Like 1
  • 2 months later...
I'm still working on wiring my Haltech in. Making some progress but now the thing won't start so (on the stock ECU) I can't test my latest connections!
I did however just purchase a hypergear ATR43 ball bearing turbo... should be here next week ?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
