I'm getting excited about mine just seeing your results! hopefully nothing goes wrong with mine! (fingers crossed)
Yeah i was surprised at the result to be honest!
ON EDGE - Yeah its just pump E-flex
Good work matt car sounds crazy on the dyno i was at JEM I heard it on the dyno.
Thanks Bobby! So glad it is finally with them! They have been amazing and the results are nothing short of impressive :D
Well done Matt, that is an awesome outcome. Makes all the sweat and tears worth it when you get a figure like that.
You must take me for a spin at Marulan, I'm not asking, I'm telling you!! Hahahaha ;)
Spin i can handle, straight line.... Maybe not so much :P
Bet you are counting down until you can pick it up
You have no idea... Although I am stuck with work commitments at the moment so as soon as I can I'll go get it, can't wait to thank Adam and the boys for what they have achieved... So far :P
I said it before and I'll say it again nice result and nice sounding car
If that was mine though I be wanting to get another 17hp out of it just so it makes an even 500
Haha thanks mate.... It sounds alright :yes:
Nope, the turbo was at its limit, pushing it harder just makes things unsafe, the tune revolved around reliability hence why i went to JEM :)
Ill play with it is for a while then consider a 3082 down the track, lets see what Kurtis comes up with first ;) no pressure champ lol
Haha thanks none at all. We all know that if i finished First you would be trying to bet me ; )
The car goal is response if I get my power goal its just icing on the cake
That turbo you have should be an animal... It'll give a good comparison between the 2 setups... Although the exhausts would be good If we had the same... You'll get your goal, I'm confident ;)
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
