Horry Shiet! Did you win Tatslotto or something? That's some nice gear you've got there.
Well you see, Mat works in packaging, and he has started doing some packaging of some unique products. Small in size, but large in quantity. :whistling:
  • Like 2
  • 4 weeks later...
cardboard aero incoming!
Actually if you look back in the pages around 30-40 somewhere there is actually a good mate fitting some up as a joke lol
So i have started up a Facebook page to i can keep updates more regular as the car has been off the scene for some time getting upgrades.
The decision was made to create a dedicated race car as that where it was enjoyed most.
If you want to keep up with the updates then head to the "Wootten Racing" page on Facebook.
For now, this is the current status of the car -
11178273_821195501283708_118421208189770
11174817_821195511283707_772756570221429
11065909_821195521283706_456016235622054
  • Like 3
Our new team logo was designed and sketched up by my fiance Carmen.
Chris has managed to take the original sketch and produce this logo which is just awesome -
GT%20Wooten%20-%20Logo%202_zpsdg9wrc2x.j
Very happy with the result.
  • Like 3
Man all you need is a dog box and its pretty much set. The Nazi tank neo is holding up well.
Neo is still holding up OK at this stage... Jez and I are waiting on our MOROSO accumulators as we are both setting one up for Nulon Nationals RD3 as we are both having oil pressure dropping under braking, the new brake and tyre combo will just make things worse i imagine so time to sort that out!
Cant wait to see this monster in action!!
Soon mate, will be booked in with Nitro Dann for some fab work over the next fortnight, then to the panel shop and then to JEZ... After that its time to test!
Like your work
Glad you like it, coming to a track near you soon ;)
Wow. I can't believe where the car has gone over the years. That engine is holding together well!
Its done a lot of hard work and been enjoyed every step of the way... I was worried what you might have thought :wave:
I told you i would never get rid of it though :D
  • Like 1
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
