annnd thats where i went...
Doesn't mean ya spoke to the same guy but anyway just offering
Expecting service from car sales people i think you'll be more often than not disappointed doesn't seem to matter if it's BMW ford audi funnily enough only half decent service I got was at Hyundai for the missuz
I'm sorry, how is that a race car?
Also: spotted this earlier
A much more realistic price for a modded 33GTST
http://www.my105.com/tabid/65/id/9483/default.aspx
looking at the pics from the Syd 34R meet... we all know I go on about 1 particular model, but 29 specimen of the same model variant, you'd get pretty over it.
*crack open bonnet*
woah RB26, no shit!
nice rear diffuser
thanks
ah so you went for the single turbo?
yeah it's a precision.
yeah I can read.
you know it's an exciting meet up when people lose their shit when a car in red and also a car in silver turn up.
FKN LOL
LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOLOLOLLOLLLLL
First day of work at new site at Rubicon near Lake Eildon. 1hr45min commute morning and same for the drive home. Fark driving that everyday. Black spur was fun but not when half asleep. Time to plead LAHA
10's start at double what a standard 7 is worth.
They are a good option if you were going to buy/lease one new and novate or salary package.
As a second hand car and something bang for buck, 10 doesn't come close to 7-8. 8 with the 6spd is currently best bang for buck imo. 6 months ago it was the 7, but the 8's have come down.
Just have a look at prices of 9's they are stupidly expensive.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
