So after 1 week of android ownership after ipad for 4-5 years..
I cannot believe I did not move over sooner.
the avalibity of apps and tools makes the locked down iOS system seem so clunky.
plus expandable memory is a god send.
battery life however is significantly reduced. however most planes have at least USB power now days so not as big an issue as it used to be.
anyhow 1 more android convert here,.
disclaimer coming from
ipad 1, ipad 2 and ipad mini retina to samsung Note 2014 edition.
  • Like 1
plus expandable memory is a rajab send.
Ahh I went the other way lol
Apple to android back to apple! May have just been bad luck but mine was crap
I found that android software development was ahead of the hardware. The more flexibility & options, the more you lag it down.
Owned the first galaxy tab 10.1 before iphone & found Apple a lot more smoother & simple.
Although haven't played with new gen android phones/tablets so that issue may have been resolved now...
Android still has a long way to go in terms of usability and polish on the overall operating system. It's also reflected in the quality of apps, which are generally awful compared to their iOS counterparts.
Working in IT, being around IT people, I am yet to see 1 IT person go from Mac to Android and then go back to Mac, ever.
An I.T person would be well educated on this and never go Mac/Apple in the first place.
Edited by brat81
I guess you just look for shit unpolished apps then.
Most apps you pay for on AppStore are free on Play
The whole app argument doesn't stick anymore, it did when android was new to the market but now it's just a null-point argument.
The only thing Apple has over android in terms of apps is Siri, Google Now isn't even comparable to Siri at any level it's just terrible, but then again Google is making it themselves from the ground up unlike apple who just brought it then slapped their logo on it and called it revolutionary.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
