ok so officially cracked it with news.com.au, I've known it was bad for years but it was easy, however when the 2 main articles for today are:
article 1
EASY KEYSY: How to buy a home with one simple, dirty word
article 2.
‘We just saved $3000 in one day’
THEY saved thousands in hours, and all they needed was one simple secret. Now these Aussies share their shopping tips to help you keep your cash.
So suggestions for Good AU based news sites?
  • Like 1
Track Skyline, boost power a little, drop insurance down loads
Daily Evo, leave stock'ish
Less stress living next to knox, less "not being able to get to work on monday" if something goes wrong on a track day, 4 doors more mohsens
article 1
article 2.
Yeah saw that today. So lame. One talked about saving and the other talked about haggling when buying anything.
Sounds like those stories they run on A Current Affair about how you could save "Hundreds" on cleaning products by going natural... and the end result is instead of buying "Toxic chemicals which could be hurting your family" you make your own at home our of shit like Bi-Carb Soda and Lemon juice... end up spending 2 hours doing 20 minutes of cleaning each week because of your sub-par cleaning products, all to save $200 over a full year.
  • Like 1
Pretty much the story behind every DIY thing that people learn to only do it once...spend twice the time learning something that could be bought with wages from half the time working one's normal occupation!
The time people waste on shit, could get a second job and earn heaps more lol
Yep, but with car or construction based DIY I still find it worthwhile for the satisfaction of doing it yourself.
I don't get that with making lemonjuice in a spray bottle to spritz on my shower tiles...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
