I wouldn't put it past autobarn audio installers to accidentally snip an airbag wire while putting in a fully sick sony xplode headunit ;)
All about the peak watts brah
Dat clipping
because chickens are very absent-minded creatures. the chances are the chicken saw some form of bug or other edible life form from across the road and decided to venture over in that direction. if the road was not there, the chicken would most likely have still crossed that same expanse of ground, regardless of potential consequences.
in all seriousness holocaust stuff isn't funny, its only funny because of how absurd and so on it is, and its that absurdity that is the funny part
anyhow,
Airbag wasn't triggering on car prior to it receiving my original engine and transmission and ECU's.
It is now. However, the SRS system is supposedly a self-contained system/unit with its own sensors, wires, and so on. Changing an engine shouldn't trigger it from what I can see going by the workshop manual.
Everything is that distinctive yellow, and there's a plug where the stock audio is, except this one is bright yellow. However it terminates short and there's nothing obvious to plug it into. Unsure if unfortunately coloured or god knows what.
Dunno if its even for the airbag, but its suspicious because nothing else was altered and the system won't even enter diagnostic mode to give me flashing lights to find out whats wrong with it all. Given this mystery plug is behind the head unit figured someone may have seen it before when they do something like... change a head unit which is pretty much done in every single skyline in australia
Srs plugs are yellow, I'm betting you're missing an srs module or something
not heard that, every-one I know that went there drank. hell my old man would not have survived if it was dry!
Was informed that Ankara is dry zone, but I shall find out if it's the case.
I know most aren't dry zone.
fark that's bad
whats considerably worse than the holocaust is a flashing airbag light
autoelecs attempt and fail, recommend replace items that aren't broken (replaced anyway)
Nissan workshop manual is inconclusive and provides not-possible diagnostic results
google fails
sau fails
genocide is preferable
You still have the stock ecu so can't my consult 3 plug into it to read stuff Greg?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
