That moment you realise the BBS LMs on your car are 17", not 18"
Oh well, shouldn't be too hard to offload the cheap AD08s. Can whack two on the GTS-T and sell other two, or could swap the LMs for a set of 18s in something else...just can't think of any particular wheels I really fancy...
$50 and a pack of winnie blues.
i just dont get why you need to get an engagement ring AND a wedding ring...
sisters engagement party tonight. says on the invitation "No gifts please". go to my parentals... "you better get them a gift!" why? "cause your family"
weddings pls. farkin gives permission to be retarded and charge money for it. its like GTR tax cept that shit is fo'eva
Don't forget the ring for first anniversary of marriage...
& dude it's ya sister don't be so stingy
How much do you want for the 17"? Need some wheels to clear 34 brembos'.
It's not about the money... If you say no gifts, why should people bring gifts? There's a table here specifically for gifts...
Pics? Offset/size?
Swap for my Meisters?
Maybe they worded it wrongly and wanted cash instead?
No one wants toasters as a wedding present lol
That but with slight gutter rash
They are 17x9+20
Honestly thought they were 18s, farkin deceiving lip
I don't mind them, they've actually grown on me, and 255/R17 tyres are pretty good value. Just a shame I bought those AD08s lol
Might whack two on the R33 and sell the other pair...shouldn't be hard to move them for what I paid for them or more
  • Like 1
but you like tri-spokes, your argument is invalid.
Tris > entire Work Emotion range.
Work Emotion range is the dullest wheels ever, designed by a boring person who has never drink alcohol or taken drugs in his/her entire life.
Don't think I've been to a wedding in the last ten years that hasn't said no gifts but a donation is welcome / leave your cash at the door
Tradition of giving gifts seems to be dead from where I see it
Says a lot about what our society/generation has become though hey
We see more value in people funding our shit / paying for our wedding / honeymoon than sentimental gifts that will last and be remembered. Maybe we expect a high chance the marriage to go down the gurgler, or maybe cash means more to us because living is expensive. Either way, it's an annoyingly faceless gift.
Yeah I probably don't want over 100 unwanted gifts such a cutlery, fancy plates, house decor etc....
Nor organising a wedding registry trying to think of things you need.
These days people also do a wedding registry where funds go to their honeywoon travels, same same as cash
I didn't 'ask' for cash in my wedding invitation but 99% of guests still gave cash.
Out of 300 people, only one couple gave me a non cash present. It was a photo frame..... uwotm8
  • Like 1
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
