3.4l RB is the most I am aware of...
also a lot of the Ford guys running sub 11 Barra's are actually de-stroking to 3.6 / 3.7 odd due to vibration issues at high RPM
Destroking? What is this madness
Edge motorworks sounds promising
Call and Barry answers
Him: You vont stroker?
Me: Yeah that or an RB30 bottom end
Him: Yah 30 torque monsta...lots of power...do that
I like where this is going
Hahaha.
Barry has built a few engines for me, I've always had good experiences.
Be patient though.
Number is 0401300028 just in case you are still waiting for a PM.
Unrelated:
Today switched from 50,000km old KU31 235s on the front and nearly bald R1R 265s on the rear to AD08 255s and AD08R 265s respectively.
Wow what a transformation. Those tyres are unbelievably good value for the $220 each they cost me. So much corner grip it's ridiculous; just turns in so well with the 255s up front. And finally a set of road tyres that can hold my 2nd gear all the way through - time to break out the G-tech again Leigh :P
Mind you, those KU31 are an incredibly hard wearing tyre. Still 40% tread left on these. Awesome value for a daily driver not pushing too much power.
Also it's friggen handy living literally across the road from a tyre workshop. Cash tyre changes and alignments ftw - dude was trying to convince me to sign up to a drift event coming up lol
so your finally working out that those toyos were NOT great preformance tyres...
what next realise that D1R's are not great light weight rims.....
that said ordering some RS3s next wek ust to not be on the Yoko band wagon .. or mroe to the point as they don;t do discounts on 17's......
how the hell do you crack a fuel tank?
I honestly want to know, because I've split four tanks now.
Four!
From two different cars.
By now, I absolutely know the plumbing of the charcoal canister back to front.
You can't even find this shit on google. Seriously, look for "R34 cracked fuel tank" and behold the lack of .. anythings.
It's quite shit. Surely I have to be doing something wrong like pumping 30PSI into my fuel tank, but having checked the lines there's nothing there.
Looks like the crack is right up top though, so it only leaks when I'm at 100% fuel. It stops leaking and the gauge is still pinned to the top, so, gonna be filling up 75% until I buy a new tank from Nissan.
I've since disconnected the charcoal canister.
But seriously, ffs.
Birds my pain is real.
I'd assume your chassis is twisted due to all of the massive torques... hopefully its so twisted that a 33 tank will fit ;)
I'm just trying to get rid of it out of the garage, so take it and see, then it's your problem and not mine.
Looking at the pics here http://www.sau.com.au/forums/topic/444306-r33-gtr-and-r33-gtst-fuel-tanks-the-same/
Looks to be very similar, though I can't remember which side some of the hoses run to. I swear they may be different but there's no way to know until the thing is out of the car. Which really needs a hoist.
If only there was a guy with a hoist who does things on the cheap...............
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
