the fords and holdens sound a little bit different to previous years. obviously the new regulations have allowed them to make a few changes. i wouldn't be suprised if we see them change to more modern race engines over the next few years. both ford and chev have race engines in their catalogue with the same sort of tech as the merc and nissan
The current pushrods donks do an admirable job. They make the figures reliably and they're light in tne right places without multiple overhead cams n stuff .....
Great race, respect for lowndes ability even though I am not a fan.
I would like to know more as to why they have restrictors on the nissan donk.
They need to do something about fuel useage as well, It seemed like an eternity in the pits.
I'm wondering if the rate that they can get fuel into the cars has changed with the change in the location of the fuel tank. Smaller diameter pipe into it perhaps?
Can confirm that this moment was very awkward for everyone in the Erebus pits.
CH 7 asked everyone to be out of the pits after the start when everyone was standing there eyeballing him lol, did managed to move the sptools banners around behind shane though before we went out.
What a weekend
Very stressful on and off the track, just absolutely fantastic to see almost 12 months worth of work come together and hit the track.
Saturday we hit our first goal, 3 cars at the end of the race ( albeit 1 down quite a few laps ) and no damage. Lots of data gathered over the weekend. issues with the fly by wire throttle on the SP tools car which meant it was pushed off the grid and visited the pits a few times.
Sunday more electronic throttle issues in the SP car and the HHA car.
One of the obvious issues with the COTF is the cabin temps, was hearing around 92C in the foot well of 1 car. all 3 of our drivers have burns / heat blisters covering their feet. visited Dave Wall and the soles melted off his shoes and drove from around lap 50 with no sole just the shoe's inner materials
This is what Dave was driving with on saturday for 30 laps in the high temps
Ouch!!
so i missed the race and news, whats happening with these nissans??
Not the most successful weekend!
if anyone thought that off the bat they were going to perform they should be slapped in the face tho....give them a season to get them setup and iron out the bugs then they will start to get the hang of things...
takes years to engineer a decent race car
Yeah but with COTF they are all pretty new cars.... They werent bad, just a few dramas.... The JD cars look pretty good on the track!
Most pre-season testing was short distances and probably in a cooler climate (cant remember where they tested and certainly dont remember the temps).
They were talking about how crazy hot it was in Adelaide
I think in a few races the Nissans might start coming good. Not saying they will be winning races, but think they will improve
The Mercedes might take a bit longer being that they were developed later then the others.
I think it wasn't even that hot at clipsal. I think I remember them saying it was just reaching 30, which comparatively is just warm. Seeing testing was over the hottest months of the year, you would have thought that this was encountered. I understand the point about the short runs, but surely the teams did some long distance runs, going through a whole tank.
Anyway, at least it will be worsted by next race. If it happens again, I would be well pissed as a driver.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
