Nothing comes easy with performance setups.
However - maybe the ITB setup is over-rated.  eg. Nissan persevered with it on the GTR and GTiR.
No sign of it on the VR38 engine, and Mitsubishi never put it on the Emo range.  Surely throttle response/control on a rally car is an important factor to performance?
In the case of the GTiR, ITBs are too much effort for what they're worth.
N/A it makes a bit more sense, and the setup is a bit more basic, but for forced induction... It makes no sense to me.
  • Like 1
On 10/16/2017 at 5:38 PM, Jordy32 said:
That plenum adapter is a shame, I asked Matt about it after seeing it installed on your car and he showed me a number of photos which look identical to the ones above. It's possible but no way is it as "bolt-on" as Otaku Garage claim..
From seeing how it was made to work in person I can confidently say there's no way they actually bolted an RB26 plenum to an RB25 head with this adapter.
Not sure what you mean? They definately work just need a decent amount of modification to existing parts which is not disclosed anywhere
  • 1 month later...
For anyone wondering what work is involved in getting the OtakuGarage ITS adaptor working, it's a lot. Firstly you have to get your RB26 coolant rail modified to clear the thermostat housing outlet. This is a fair bit of work and is certainly a job for a fabricator. When doing this you have to removed enough material for it to clear but also leave enough to not create a bottle neck in the coolant passage. Then you have to find an RB30 thermostat housing as a normal RB20/25/26 one won't work without a large amount of grinding on the acutal ITB's. Then you have to replace the bolts with M8 studs and nuts, and the top stud has to be shorter than the others. Then you have to grind  away the lip around the outside of the RB30 theromstat housing, and grind even more away where the bolt for the coolant rail will foul the housing. It is a small mission but doable.
You should be able to see most of what i am talking about in these pics.
  • Thanks 1
Whoops, forgot to post the pics. But yours are basically identical to what I would have been posting. Cheers.
Got any pics of it fitted up in the end? Noticed you havent posted an engine bay shot since the update :)
Well what do you know, I haven't either haha. I'll get one up soon when I provide the remainder of the updates for this year.
  • 6 months later...
Hi, sir... I found this thread doing a search and it is nice :)
I was asked (as often happens) to try and match a nice turbo for a mates RB25 track car with some very specific requirements, ie ball bearing, within a limited budget, T3 open flanged and able to make around 450kw @ hubs on E85 on a Dynapack dyno.   I did some crawling around and decided to pay more attention to the GTW3476R than I had really given it previously (Garrett took AGES to release flow data for them) and I was actually pretty blown away by the match that they give, at least on paper.   They actually look like an awesome combination from that point of view.
How have you found you found yours so far?   Real world response etc fairly acceptable for the power you are making?  Was that power figure "all in"?
Cheers
  • 4 months later...
Cheers
Thanks mate. Sorry the delayed response, don't really frequent on here anymore.
Have found the turbo to be great for what it is. I'm running the bush bearing version. Was previously running the .86 twin scroll rear housing which made 420rwkw on ~26-28psi. Response was great. We've recently changed the setup to a 1.01 rear housing to help with getting more heat out as I kept melting the diaphragms in the gates. As a result I'm currently making 370rwkw on 22-23psi (need a new boost controller) and I'd say a few hundred rpm laggier, but much nicer curve coming on. Will put together a big update post eventually, but feel free to pm me if still looking for info.
  • 5 months later...
Well guys, the time has unfortunately come. I guess I'm turning in to an old fart as my baby for the last (almost) 7 years is up for sale. If you know anyone that is keen, link below with as much info as I could remember.
Well that was unexpectedly quick, but I guess this chapter of my life has finally come to an end. Car is sold (getting picked up this week). Big thanks to everyone on this forum that helped out in one way or another, or just talked banter. See you all around once I figure out what's next :)  ?
  • Like 1
  • Sad 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
