Nothing comes easy with performance setups.
However - maybe the ITB setup is over-rated.  eg. Nissan persevered with it on the GTR and GTiR.
No sign of it on the VR38 engine, and Mitsubishi never put it on the Emo range.  Surely throttle response/control on a rally car is an important factor to performance?
In the case of the GTiR, ITBs are too much effort for what they're worth.
N/A it makes a bit more sense, and the setup is a bit more basic, but for forced induction... It makes no sense to me.
  • Like 1
On 10/16/2017 at 5:38 PM, Jordy32 said:
That plenum adapter is a shame, I asked Matt about it after seeing it installed on your car and he showed me a number of photos which look identical to the ones above. It's possible but no way is it as "bolt-on" as Otaku Garage claim..
From seeing how it was made to work in person I can confidently say there's no way they actually bolted an RB26 plenum to an RB25 head with this adapter.
Not sure what you mean? They definately work just need a decent amount of modification to existing parts which is not disclosed anywhere
  • 1 month later...
For anyone wondering what work is involved in getting the OtakuGarage ITS adaptor working, it's a lot. Firstly you have to get your RB26 coolant rail modified to clear the thermostat housing outlet. This is a fair bit of work and is certainly a job for a fabricator. When doing this you have to removed enough material for it to clear but also leave enough to not create a bottle neck in the coolant passage. Then you have to find an RB30 thermostat housing as a normal RB20/25/26 one won't work without a large amount of grinding on the acutal ITB's. Then you have to replace the bolts with M8 studs and nuts, and the top stud has to be shorter than the others. Then you have to grind  away the lip around the outside of the RB30 theromstat housing, and grind even more away where the bolt for the coolant rail will foul the housing. It is a small mission but doable.
You should be able to see most of what i am talking about in these pics.
  • Thanks 1
Whoops, forgot to post the pics. But yours are basically identical to what I would have been posting. Cheers.
Got any pics of it fitted up in the end? Noticed you havent posted an engine bay shot since the update :)
Well what do you know, I haven't either haha. I'll get one up soon when I provide the remainder of the updates for this year.
  • 6 months later...
Hi, sir... I found this thread doing a search and it is nice :)
I was asked (as often happens) to try and match a nice turbo for a mates RB25 track car with some very specific requirements, ie ball bearing, within a limited budget, T3 open flanged and able to make around 450kw @ hubs on E85 on a Dynapack dyno.   I did some crawling around and decided to pay more attention to the GTW3476R than I had really given it previously (Garrett took AGES to release flow data for them) and I was actually pretty blown away by the match that they give, at least on paper.   They actually look like an awesome combination from that point of view.
How have you found you found yours so far?   Real world response etc fairly acceptable for the power you are making?  Was that power figure "all in"?
Cheers
  • 4 months later...
Cheers
Thanks mate. Sorry the delayed response, don't really frequent on here anymore.
Have found the turbo to be great for what it is. I'm running the bush bearing version. Was previously running the .86 twin scroll rear housing which made 420rwkw on ~26-28psi. Response was great. We've recently changed the setup to a 1.01 rear housing to help with getting more heat out as I kept melting the diaphragms in the gates. As a result I'm currently making 370rwkw on 22-23psi (need a new boost controller) and I'd say a few hundred rpm laggier, but much nicer curve coming on. Will put together a big update post eventually, but feel free to pm me if still looking for info.
  • 5 months later...
Well guys, the time has unfortunately come. I guess I'm turning in to an old fart as my baby for the last (almost) 7 years is up for sale. If you know anyone that is keen, link below with as much info as I could remember.
Well that was unexpectedly quick, but I guess this chapter of my life has finally come to an end. Car is sold (getting picked up this week). Big thanks to everyone on this forum that helped out in one way or another, or just talked banter. See you all around once I figure out what's next :)  ?
  • Like 1
  • Sad 1
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
