I'm using an AEM UEGO as well. Thing is, I'm not totally confident it is 100% accurate. I have a feeling it might read a bit rich, otherwise my tune is extremely rich. Frequently seeing ~12.5 on cruise. But I need to ask my tuner to check how accurate it is next time it goes on the dyno.
That said, I'm otherwise happy with the AEM. I've just finished wiring it into my G4 expansion harness which was very straight forward. The Zeitronix kit looks the goods as well though!
Mine seems to be pretty accurate and very responsive!
I use Innovate MTX-L, appears to be a tiny bit laggier than my old Innovate LC-1.
I installed a AEM UEGO on Phil's S15 not long ago and they seem pretty good in terms of response, however his is mounted a little closer to the exhaust housing of the turbo where as mine is mounted pre cat.
so where is the point of difference in all these products?
the sensors will be quite similar yeah? just bosch units or what-not? is the difference in the controller bit? i thought all we want it to do is send an accurate AFR and that's it and let the ECU handle the rest?
if you are aussie there is no reason why you should not use the techedge. you don't even have to buy the display with it which makes it cheaper.
been using them for years, and i own 2 units now. cannot fault them at all. I even had a issue with the long sensor cable and he was nice enough to replace it for me for free when it was not really even covered under warranty and the turn around time for the repair was only 2 days.
all parts and cables are available to purchase seperatly, so you don't have to buy a whole new wideband sensor if you destroy the power cable or the wide band cable.
all he does and all he has ever done is build wideband meters, no one knows as much about wide band as this guy.
cannot beat that shit.
Yep I splashed out on a TE WB3A2 and all manner of cables and adapters a few years back . It has all kinds of logging abilities most of which I'll never use . It's wired into a Vipec plug in nowdays and works really well . The only thing I ever did was drop it in to TE in Canberra to adapt it to their current fastest I think Bosch LSU 4.9 probe . It heats up faster than the one it came with and my tuner requested a new probe when the plug in was fitted and tuned .
If you only want an 02 input for your computer you can buy them cheaper and not pay for features you aren't using . I use the small LCD display so I know what's going on when the lap top isn't online .
I'd buy Tech Edge again , cheers A .
yeah i got the 3A2 as well, had it since 2007 i think... its still going strong. its got the usb interface. its been dropped, wet, left in 55deg + heat for days on end and its still going strong.
I also go the basic 2j2 unit.
if you want a good unit for tuning cars then grab 3a, if you just want one for one car the 2j2 works great.
these things are rock solid, why bother with the seppoes crap ? you dont use AEM computers why use AEM wide bands ? its just silly.
I got this depo gauge...seems all right has Bosch sensor..
Started reading lean, turns out my fuel filter needed replacing...replaced fuel filter now wideband reads error...tried to calibrate it but no response..:unsure:
Pretty sure sensor is still fine , if unit is dead can I just get the techedge so I can link it to my adaptronic?
I seem to misplace a bookmark about wb testing, AEM was at the bottom in terms of how fast it reads and accuracy. A .01 difference compared to LC1 and the other brands that was tested. I had an LC1 first unit was DOE got a new one and it worked peachy.
Im going to try and google n see if I can find the article.
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
