If you have some spare springs available I would chuck something like 7 or 8kg/mm on the front.  If you have some anti roll bars I would do that too although 27mm front sounds odd.  Is it a Whiteline bar or a Cusco?  From memory they are smaller. 22mm?  Anyway the idea is to add more roll stiffness to the rear relative to the front.
Whatever parts you may have try them out to get a feel for setup direction.
At the moment your 16kg spring is trying to resist about 3/4 of the roll which loads the tyre up hard relative to the back.  Then you are asking it to turn aswell.  So you get understeer.
  • Like 1
it was a 27mm front... was a whiteline but custom made... it was the setup I used on my drift car and changed everything when went to MCA reds and therefore std sways
Ive sold those bars now... pretty sure 24mm front 22mm rear is the standard whiteline / r32 setup for circuit
I still have a full set of the teins sitting in a box at 7 and 4  but also have the spare MCA springs
I agree with you on the roll control and turning..  that was my thoughts also ...
updates on recent happenings
I wont post a pic of the new diff and tailshaft because well it looks like a diff and tailshaft :6_smile:     but   preload taken out of diff, breather tapped and line run through the floor into a mounted canister / breather. Tailshaft is a 1 piece - saved 4kg there also
With that done and the car back at home came the time to sack up and get working on the splitter - can only give these things a go and its cheap enough and just some hours in the garage to get it done
Basics for those DIYers at home
Specs = 1900 wide, total length is 1200, rake from front to back is circa 2 - 3 deg (roughly)
               The splitter itself weighs 6kg ... total weight with frame nuts bolts paint everything is 10.1kg without cutting any bolts to length yet
We actually took just over 1kg of tags etc etc of metal out while we where under there  and saving on tailshaft so far above happens net a 5kg+ gain in weight - albeit at the front
We extended some tube ally out the back of the splitter to some sleeves welded tot he chassis rail behind it for stability and ease of install, once slid in there is 6 x 12mm oem bolts to bolt up which is made from tags with oem nuts welded to the back
the ally frame is welded and then bolted to the splitter using m8's and also sikaflexed down
Tested it with 50kg in middle 3rd and 30kg on each other third adding weigh bit by bit. Strong no flex at total weight of 110kg with front end coming down 25mm with that weight on spring compression. Didn't go any heavier just wanted to see if it was going rip of easily or not haha
all back yard read > making > hoping > trying - but that's half the fun sometimes
the front lip of the carbon airdam is / will be held down using 7 x M6 bolts with nylocs
painted for looks
The current height is 850 front the ground , will be lower the car by 5 mm to get it down to 800 which will be enough, not optimal but don't want to compromise suspension geometry
And pic just because
Out in two odd weeks to try and go round and round a track fast
Just basics to do now like wheel alignment and fluids change / check
Sway bars are on order but wont be here in time try this..... add sways try that... see if successful in either pursuit and see if I can get some consistent track time over the next 3 months
  • Like 5
Its probably the way the photos are taken Id say its wide but not that wide
the carbon lip that comes down directly off the GTR bar is 178cm wide, outside tyre to outside tyre across the front is 182cm and the width of the splittler is 190cm - so its only 6cm a side wider that a normal GTR width and 4cm and side wider than the tyres so when you look at that its not bad at all really
And I just do sprints so basically no wheel to wheel action :1310_thumbsup_tone1:
Quick update:
Went out last wed night. Really good night heaps of track time which was great sat a few session out because well Im old and me and the car gets worn out :1_grinning:
Long story short the two handling changes being the splitter and the diff has made the world of difference. Id say mostly the diff but all contributes as you know. I have a car that turns now !!!!   so good
With invention of actually turning around corners not just the rear end pushing the front through it means I have to accept that I cant just mash the throttle on exit on go so little later on the throttle now with a decent hint of oversteer if  you get it in the wrong  spot, my drifting skills are a bit rusty but got tested a few times trying to find the new limits.
With the wing on 0 deg angle, the rear grip alignment was set at neutral and the rear dampners on hard there is much room for more rear grip to be added
I spent most of the night trying to find the new balance as it really was quite different but feel like im actually driving the car now and have taken the handling problems from really big to a now manageable amount through tuning with what I have and am getting.
New PB was set just on 5 event old tyres and we did a top 10 shootout at the end of the night (one lap dash) an I was within 0.8 sec of PB on cold tyres etc
All in all moving forward and much happier.... for now :8_laughing:
Edited by bcozican
  • Like 2
  • 3 weeks later...
Build bits and results
Few little additions recently. Trying to run the ride height I wanted to ie: lower was leading to suspension geometry issues. I bought some gkteck knuckles that had 20mm drop built in to attempt to correct that. After what I admit was a fair bit of messing around with the usual change one thing and effect 5 other things we got these in with new bearings, wheel studs etc etc. It served its purpose for both correcting steering geometry and also letting me run the ride height I wanted but correctly.
The new tailshaft over the last event and a test and tune was rattling my teeth out with vibration so gave it back to Final Drive who rebalanced it and put that back in and all is good now
Off to Allstar to final give the power a bit of touch up... been running 490hp and 550nm @19 psi successfully Sean gave it another tune I can run off a switch adding 4psi so now 550hp and 660nm full boost at 4100. That's a fair bit of pick up from 4psi.
Everything on the car to remain 'balanced' without it being too pushed or unsafe ie: brakes is made for 500 - 550 hp - try for anymore and I really run out of turbo, injectors, clutch, brakes
The car was also due for some new tyres - I had some fronts I bought cheap from over east new but 3 years old and some new ones for the rear
I also picked up the Vbox for future events so will get that in soon.
Last night ran at the Trackbattle night I like these night cruisey but decently professional good amount of track time and good people. After a bit of rain gave this thing a crack and got a new PB by a decent amount knocking 0.9sec off my existing PB ....lap time doing 2 x 62.1s and I think about 7 - 8 laps in the 62's
Edited by bcozican
  • Like 4
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
