On 25/11/2021 at 6:44 PM, Unzipped Composites said:
*whispers* hey @bcozican, I'll just leave these here:
😅 when your mate / aero / composite guy is keen
Can follow more updates on iface: Brandis Racing R32 Skyline or Insta: brandis_racing
So recently I won WA Time Attack  - Overall winner won the whole thing
Set a lap time of 57.97 sec which was only 2 tenths off the lap record for a tin top on semi's - we'll have that record soon!
To give some perspective for people using the standard V8SC best times at each track this would put us at a 1.338 at SMSP and 7th in open class last event at WTAC
Was quite a decent lead up to the event with decent testing and runs few things went wrong but nothing major, this was the first time we'd run the car on new tyres and max power so alot to learn still and alot more in the car/ driver combo
some pics from the day :
Some other pics in lead up to event
Engine bay and splitter:
From a twlight prac a few weeks before:
If anyone wants to know anything about the car just ask !
Edited by bcozican
  • Like 7
Amazing stuff, well done!
I've liked your FB as both myself and the No Crust page to boost those social numbers bruh
Onboard lap looked pretty smooth, like there was more in it but can never tell from the desk, good driving :)
  • Like 1
thanks mate
I'lm all about the socials hahaha not really its more a requirement
laps got more in we think there is about 1 sec in it with current setup
3 glaring errors - broke too early into turn 1 down , miss shift somehow down back straight, off boost on last cnr T7
  • Like 1
🤣🤣 sorry buddy, I gotta keep on your case otherwise you'd win things and set records and not tell a soul!
  • Haha 1
not now no - the air guiding etc @Unzipped Compositescreated is awesome and has done the job well
but yes.... I was running fan and shroud up until recently and all my previous incarnations of the car - we took it away in stages to make sure everything worked ok - so took shroud off, then fan
  • Like 1
was a gkteck fan (only because I couldnt source a stocko one) and stock shroud
Ive never run a electric fan so cant comment from personal experience
even back when I was drifting I still ran stock fan and shroud - theory over here is nissan spent alot of money on r&d to get that stuff right maybe moreso than an after market option so we'll run with that
fans really only needed for cooler car in pits or at very low speed if you have decent ducting etc other than that its really just drag as air moving in goes faster than fan - shroud again is great and no probs as many fast cars inc. mine have done fine with it but really is drag
some ive seen have just run small electric fan that turns on via ecu at certain temps enough to keep it cooler but small enough to not hinder air movement through the rad properly
looks good, maybe a bit of trial and error if you look back in pics I had a very similar setup to that just with a panel across the top of the intercooler and worked well
that'll be alot of direct air volume going through there at speed - maybe do the bit by bit like it did
also depends what the car is for etc
my air guide entry below is tiny but expands up over the top of the intercooler into the exact same size your have showing and I can do 5 hard laps at 25 psi circa 590 rwhp no probs
Edited by bcozican
  • Like 1
On 12/13/2021 at 10:19 AM, couchboy said:
Cool cheers, yea I'm tossing up which one I should do. I've ducted the air so it goes to the rad, but it probably won't be enough.
I have run something similiar in the past to great effect for from opening in front bar right up to the rad and sealed with foam. No temp issues at big circuit and helped IATs.
With my rebuild I am going make similiar to bcozican's setup as looking to improve front end aero
  • Like 1
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
