Where am I at ?  as usual here now prob a dump of accumulated months and months
I have decided to do some upgrades both to advance the car and also create a spares package to reduce time off track should something occur... all the theories
there is engines, bodywork, technology and just stuff....
So pulling the car basically all apart
New engine will be built to rb28 specs the current decent built rb25 will be a spare
Head starts as a hydro rb25 head but full porting, supertech solid conversion + other goodies also the usual Kelfords etc etc
100802806_NewBlock.thumb.jpeg.25015a86fd8df730bf276750bf2ca456.jpeg233962441_Supertechhead.thumb.jpg.e94e203453cfbd24f4471a16777f0f4b.jpg
I use a 5 - 0 Ignite trigger kit - they upgraded me to their new 36 -2 situation
Updating the rad - the Koyo has done its job and moving to a PWR crossflow
Ive been running 9.5" rims with 265/35 tyres up front to date - they have done the job but really are struggling and get torn to pieces so move to big boy tyres means alot of changes - going to 295/35 is a huge diameter jump and some width
New TC105X 18 x 10.5 + 12s acquired
A struggle is to fit the combo into the arch etc as it hit alot of places so we added some inner clearance modding the J arm and now all fits nicely
443196927_ModdedJarm.thumb.jpg.8e62fa099e2f03476694062b4d657c23.jpg1742659781_BigTyreJarmclearance.thumb.jpg.54beab86ecdfd756fae958f4849b857a.jpg
Have gone the Motec dash route for data - not that i know what Im talking about but others do so they can use the info
One of the upgrades is also Bosch MS ABS for braking and outward sensors for wheel speed allowing lots of data for the likes of traction control, the diff guy to get info and blaa blaa
733778107_BoscheABSgear.thumb.jpg.01c8ccd6097b771ce4c789cf52b37fd1.jpg19684342_FrontHub.thumb.jpg.f51b1fe4d3ce36024b813d2c907c856e.jpg806018363_RearHub.thumb.jpg.1b76472adec870c7916ca66e4b16221d.jpg
I think thats it for now
Edited by bcozican
  • Like 7
Says Mr. engine and upgrades himself 😄
Eh not here to be showy, but also got nothing to hide on my build have spent lots yeop and just hope I go faster lol
I just got inspired and sort alot of info through reading about cars on this forum so put it out there in case someone has a question or might want to try something
Ye I prob seem like ABS fan boi been talking about it for ages finally just threw it in the f*ck it bucket and bit the bullet
  • Like 1
  • Haha 1
yes to traction control the sensors are there so why not - it'll be through Haltech - I know there are better out there but cant have everything... yet. How good it'll be will be interesting and up for debate till proven in a practical situation
Interesting for those playing at home, apparently outboard sensors on the hubs vs using those in std gtr etc off the diff increases the accuracy of the data dramatically as there is so much chatter that comes off the diff
  • Like 1
f**k me, 10k for the ABS?
Will be interesting to see how the difference feels.  I've been living with 3 channel, 30 yo ABS for a long time, would be very interesting to see how it feels back to back.
  • Haha 1
That was my reaction when I looked at pricing.
Given I am about to replace my master, is it worth me trying to implement basic Nissan ABS? I was also under the impression it was not suitable for motorsport.
I'm just going to a BM57 to match the 350z Brembos - the car has never had ABS.
Edited by ActionDan
Ive been living with no ABS
back to back will be hard considering I am making so many changes at once but obviously feel etc blaa blaa
I also saw it (we all stretch for any justification in these circumstance's) as a combo thing coupling the traction control - so that halves the cost ???  bahaha
  • Like 1
On 29/07/2022 at 1:21 PM, couchboy said:
The J arm mod, did you do it just for that section because it was the most like aera to hit the tyre and also did you think about carrying it around to the top were it bolts to?
It was the first incarnation of this thought process
The tyre shouldnt reach there any tyre deflection under load should be squish which is sideways so shouldn't need ? 🤷‍♂️
Also need to add bracing to the back of it for support
  • Like 1
I have all adjustable arms etc but yeop bolted up fine
I now know of 2 more r32 gtst and an R32 GTR running r33 / r34 gtst (same) front knuckles also - so should bolt up fine  * all have fully adjustable arms though
Edited by bcozican
  • Like 1
Got a new diff built
S15 housing to match what my current one is
Nismo GT pro 1.5 centre
Neat gearbox new 4.11 gear set shot peened & polished
Gktech rear cover for extra oil - takes 2.1 ltrs all up
Moving from my current 3.7 gearing to 4.11 to make use of more engine and revs and bigger profile tyre means I was geared to break land speed records and the gear although was nice and 'safe' to roll around at relatively low revs really wasnt right
my current diff is built almost to the same specs - will be going 4.11 also and be a spare, hopefully I never have to use it though!
  • Like 4
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
